Re Frigidaire 104P1A - Neighbor below me is complaining the unit is draining INTO her window (she needs/wants to have it open). I had someone out to adjust the level of the unit, tilting it back slightly, but this is not solving the problem. Is there is no way to re-route the condensation with a non-slider window unit? Suggestions most welcomed.
You need to vacuum the coils in the back of the fridge and make sure you have a drip pan under you fridge. The fridge will over work itself because of buildup dirt.
Posted on Jul 19, 2009
I live on the first floor of a two-story Condo. When my upstairs neighbor's A/C is running I get a loud "gulping" sound coming from my handler. What could suddenly be causing this?
Your drain line is not "trapped" properly. When your neighbors unit comes on its suckin air from your drainline. Make sure your drainline is trapped before it goes into common drainline.
Oct 20, 2017 | Heating & Cooling
Where is there a drain hole for the water?
Your Frigidaire window unit is the same as any other window unit. Typically window unit air conditioners don't have a drain. This is why you have to make sure the back of the unit (the end that goes outside) is slightly lower than the front when you put it in a window. When it gets so high with water it drains out the back onto the ground.
Sep 18, 2014 | Frigidaire Heating & Cooling
Frigidaire FAC107S1A leaking water thru the inside of the house
Hello, first make sure the unit is tilted back in the window about a 1/4 inch. Also, check the drain on unit, sometimes they can clog and prevent condensate from draining.
Jul 31, 2012 | Frigidaire FAC126P1 wall/window Air...
Frigidaire Window/Wall Unit Dripping onto neighbor downstairs - suggestions for redirect?
Hello, you can use a drain hose and coonect it to the outlet of the drain hole. This way you can terminate the hose away from your neighbor.
Jul 08, 2012 | Frigidaire FRA186MT2 Window Air...
My neighbor below me is complaining that my air conditioner is dripping onto her window. I have had this ac for about 7 years and this is the first year we are experiencing this. Are there any...
Air conditioners work by taking water out of the air, so there is some drainage needed. It is possible your drain line is clogged and it isn't coming out the normal drain. You can also add an extention to the drain line, to get it past her window. Just make sure you route the line no less than one inch per foot drop if you can sideways.
Jun 29, 2011 | Friedrich WallMaster WS15A30 Air...
Leaking water from underneath.
Hello my name is Heath it will be my pleasure to assist you. The drain should be in the back of the unit outside . If you lean the air conditoner slightly toward the outside it should drain outside.
Jun 28, 2010 | Frigidaire FAA084P7 Thru-Wall/Window Air...
AC draining into neighbors window
we had this issue inside a warehouse, after carefully watching where the water exited the unit, we used a 3" pvc fitting to collect the water and then reduced it to 1" pvc and ran a drain line to a non-objectionable place. obviously if you are on the tenth story of a building this may not be an option... just an idea :)
Jul 19, 2009 | Frigidaire FAC126P1 wall/window Air...
Frigidaire Portable 10,000 BTU air conditioner
Lots of HVAC contractors in South Jersey at this time of year. Look for one of their trucks or ask a neighbor.
Jul 03, 2017 | Frigidaire FAP094P1Z Portable Air...
My fridgidaire ultra quiet 3 dishwasher leaks...
a common place to leak on these machines is through the heater leads. run the machine w/lower panel off and see where its coming from , if its dripping down the heater leads, chances are the 2 nuts that secure them are broken and need replacing
Mar 04, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
