Question about Canon PowerShot A75 Digital Camera
LCD monitor My lcd monitor used to periodically go black, now its black altogether. I can still take pictures, and download them to the computer. Just no viewing on the camera. Any suggestions?
  • Anonymous Dec 08, 2007
    My A75 screen started to go dim, now only produced the Canon logo on
    power-up then us dark. Camera takes pics and am able to download
    okay...but no display and no settings/etc.!!!
  • sambaiam Dec 09, 2007
    I have the identical problem; the canon logo appears when camera is turned on but then fades to black. I can still take photos and download them. If it is the backlight (as the soultion offered) can this be fixed by me? Thanx!
  • 33 Answers
Sounds like your backlight may be out, unless you're still able to see a faint image when the LCD is "black"...?
If you can still see a faint image of what your camera is pointed at, I would assume your LCD is bad. In which case you could purchase a new one on for ~$60 or have them do it for you for ~$85.
Posted on Nov 19, 2007
Vaio LCD problem
Periods.......Nice little items because they denote the End of a sentence.
See how this works?
"I have a vgn cs36gj, I was working with it, suddenly the LCD became pale black, I connected it to external monitor and it has a picture, sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
Now you try it.........
"I have a vgn cs36gj. I was working with it, suddenly the LCD became pale black.
I connected it to external monitor and it has a picture."
Okay, I got that part.........
"sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
Laptop LCD?
External monitor LCD?
Man on the moon LCD?
1) If the external monitor LCD goes 'pale black', the problem is the graphics chipset.
This I do not believe
2) If the laptop LCD goes pale black, this I believe.
Post back in a Comment.
Apr 25, 2013 | Computers & Internet
Acer al2223w lcd moniter is blacking/blanking out upon boot up and also while the computer is on. any ideas on how to slove the problem?
it is the problem of the LCD panel .it is replacable .go for guarantee if not finished the period thanx plz vote
Feb 28, 2011 | Acer AL2223WD (Black, Silver) LCD Monitor
When a press alt+tab the monitor has no picture but it still on and no picture like all black
Try connecting the monitor to another computer to see if this problem is also on this computer, if so then the fault is the monitor, if not then the fault is the video card in the other computer.
If the LCD monitor has a faint Windows image, then the LCD monitor has a back-light problem and it could have a faulty inverter board or a faulty CCFL lamp.
Parts and service are available from LCD Parts, their WEB site is :-
Jul 12, 2010 | HP w1907 LCD Monitor
My monitor is flickering when i use it in a long time period..and the display will black out...but when i tap the back casing,the display will show up again...
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them. and
Good Luck!
Jun 13, 2010 | ViewSonic VA721 17" LCD Monitor
Black screen of death on a VIZIO LCD HDTC
check the warranty period
picture board problem so if not under warranty get a proper diagnosis done and a quote
Jan 27, 2018 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Describe your Dell E173FP 17" LCD Monitor Problem The monitor seems to be turning itself repeatedly on and off. No picture is ever seen, the screen stays black with a slight flicker.
Sounds like the monitor is cycling power.
Try plugging the monitor into a different power socket. Try not to use the same power bar as your computer
Mar 24, 2010 | Dell E173FP 17" LCD Monitor
My lcd monitor loses the picture. it is still on
Sounds like the bulb in your LCD screen is going bad, or the LCD inverter or cable is going bad.
If moving the screen back and forth causes the LCD screen to show a picture normally, but intermittently, then the LCD cable is probably bad.
Jan 26, 2010 | Computers & Internet
Check video cable keeps reading and go off, but the power is still on
the screen on most monitors will go black if the cable connecting them to a device is lose or disconnected altogether. try the cables in the back the ones other then power cable
Apr 15, 2009 | Neovo F 415 (Black) 15" LCD Monitor
Switched from crt to lcd, no display!
You need to install the Display driver shipped or downloaded from net.
Mar 31, 2009 | Samsung SyncMaster 171 V 17" Flat Panel...
Blank Screen..Will not power off
Have you checked your video source to ensure that this isn't a problem with your PC or whatever you're displaying on it? Try using a different display and see what happens. Try putting this LCD on a different PC and see what happens. If indeed it is this screen then it could be something as simple as a loose cable. Start simple and work from there.
Dec 27, 2006 | Proview XL775I (Silver) 17 in. Flat Panel...
Canon PowerShot A75 Digital Camera Logo
66 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
