Question about Nintendo DS Lite Console
My ds turns off randomly when at full power
When I've been playing games for 5 or 10 minutes my ds shuts off.
    Scholar:
  • 151 Answers
Are you sure you have charged it until the red light goes off?
Posted on Jul 19, 2009
My nintendo DS will not work when i place my ds card inside and the game is not there
Try turning your DS power off then let it cool down for a few minutes. Before that take the game out. When you've let it cool down for a few minutes put the DS game back in and see if it has worked.
Jul 15, 2012 | Nintendo Pokemon Black Version for DS
System turns off when playing the gameboy sp games after about a minute or two it just shuts off like you turned the power off .It works fine when I play ds games but no matter what when you play a sp game...
I would open the DS and make sure all the wires are hooked up correctly in the bottom slot if they are then call Nintendo and ask if they could repair it.
May 09, 2010 | Nintendo DS Lite
Hi, I have a DS Lite 2 years old and I noticed that in several games it´s turning off suddently while the game is running. Restarting, the game starts from the beggining.Sometimes the problem appears...
If you have dropped or bumped the ds lite hard against something then it's possible the black coil near the power switch is loose. This can cause it randomly shut off. The coils is the round topped black thing with 100 printed on it. There are several on the motherboard but you're looking for the one closest to the power switch. Just heat up the solder on both sides of the coil and it should reseat it.
Jan 05, 2010 | Nintendo DS Lite Console
Nintendo ds lite that shuts off unexpectedly
Hi again,
Ive been doing a bit of research and it seems that if the DS lite has had a knock the black coil near the power switch could have been knocked loose which would make the DS lite switch off randomly. If you want to see if thats the problem take the DS lite apart (for a dismantle guide click here) and check to see if its loose... its the black round thing with 100 written on it near the power switch. If its loose then heat up the solder round it and that should reset it.
If thats not it check the L2 transistor is firmly in place, again if its loose heat the solder and reset it.
Another thing you can check is the power switch make sure its solid and doesnt wobble internally i.e. the black moveable part only moves the way its supposed to, as well as checking the solder is solid.
Hope this helps, if it doesn't sort out your issue then get back to me and I will continue to help you.
Regards,
SOD69
Jan 04, 2010 | Nintendo DS Lite Console
Nintendo DS lite random shutdowns
have you tryed playing it while its charging?
Aug 24, 2009 | Video Game Consoles & Games
Nintendo DS shuts off randomly
try to play with the poweradapter connected. If the problem still there you will need probably a new mainboard for your nintendo. If the problem disappears probably a bad battery is the problem. If you can exchange your battery with another NDS lite you can check if it is the battery or mainboard.
Jul 06, 2009 | Nintendo DS Lite Console
DS Light shutting off randomly
I know this may sound stupid and obvious, but are you hitting the power switch while playing? I used to have the same problem when playing "intense" games like racing when I would get totally absorbed and then all of a sudden my DS would shut off and I'd be like WTF?! I took it apart and switched batteries and found nothing wrong with it. One day my sister was watching me and asked "Why did you shut it off?" and then I knew. The power switch is very sensitive if you hit it even just a little it could be enough to shut the power off. I suggest just monitering what happens when the power goes off. Is it a specific game that shuts it off? Enviornmental effects? It should tip you off to the problem. If all else fails you could contact Nintendo and just see what they have to say. =)
Mar 29, 2009 | Nintendo DS Lite Console
Ds randomly switches off
its called repair man you should visit him some time
Mar 11, 2009 | Nintendo DS Console
DS keeps turning off randomly
Maybe the Ds gets overheated if you play on it too much I suggest that you should leve it for a bit.
Hope this helps!!
Oct 19, 2008 | Nintendo DS Lite Console
Nintendo DS Lite shuts off randomly.
I'm a certified electronic technician and I must say NDS internal screen ribbon connectors are junk! Basically The ribbon connectors are so sketchy that it is not recommended to ever unclip them, if you do there's a good chance it will ever work again once reconnected due to how the connector pins slightly crimp into the ribbon pads.
When a NDS boots up the the onboard firmware constantly tests the LCD screen connections, if there is a break in the connection the NDS will shut down. If your NDS randomly turns off, fails to boot, or powers of when you move the hinge it is most likely the ribbon (flex film) or ribbon connector has failed. The only option to to replace the affected LCD screen.
Jan 08, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
166 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
