Question about Hobart D300 Stand Mixer
Planetary shaft for h600 is bent
The shaft going from the top of the machine to where the agitator is i think is bent, it goes back and forth and grinds against the trim ring. so i got in there and got all the gears of the shaft but it doesn't want to come out, it moves up and down a few inches but doesn't want to lift out, how can i get the shaft out, do i need to remove the other 2 shafts with gears on them in order to get this one out?
  • 640 Answers
Thats the center shaft and if it moves back and forth the lower bearing is bad or the shaft has cracked.You need to remove all 3 shaft assemblys. if you already removed the gears on the center shaft then you need to remove the shifting yoke---turn power off to machine then take the screws off the trim plate where you shift speeds,you might see a switch that sits up on the shifter cam,remove the screws and put switch aside,take the 4 allen screws off and pull on the shifter(it will come out).If you didnt already drain the oil do it before you mess with the shifter.after the shifter is out grab the upper left gear assy. and the gear assy. below it,rock both gear assy. and pull up,they will both come out(you might need some force)once out remove the remaining gears on the center shaft and remove the shifting yokes.you then need to remove the planetary (lower part of mixer)if not already done,then pull the shaft out from the bottom.any questions let me know.
Posted on Nov 19, 2007
I have a Hobart Kitchenaid K45SS mixer and want to know how to remove the agitator shaft from the planetary so I can paint the planetary.
To do this, the whole planetary news to be removed. Use a light hammer and 5/32" pin punch to drive out the pin holding the planetary in place. Then use two flat-blade screwdrivers placed on opposite spots under the planetary and push down on the screwdriver's handles. This will force the planetary up and off the central drive shaft.
Now you can remove the agitator drive shaft which is held on (depending upon the age of your mixer) by a screw or ring atop the gear at the end of the shaft.
Re-assembly is the reverse process. Be careful to line up the pin''s hole in the planetary with that in the drive shaft so that the pin can be driven back in place.
The Service Manual can be downloaded from:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Jun 07, 2017 | KitchenAid Food Mixers
Professional 600 575 watts 6 qt. beater stem is loose and lets beater drop onto bowl.
b68be83b-c0cb-45d6-8d74-337f1cf098bd.jpgThe part you see is called the planetary, it has two shafts, the long one is called the center shaft and if it is falling off you need a new planetary, the second shaft (shorter) is called the agitator shaft (the beater attaches to it, if this is the culprit then1 you are not attaching the beater correctly2 the locking pin that the beater attaches to to hold it in place is missing3 you have way too much "gunk" build up on the agitator shaft and the beater is not attaching correctly4 if the beater falls into the bowl with the agitator shaft still attached you have three additional problems a) the snap ring a top the agitator shaft has broken off or come off which in turn means that
b) the gear at the top of the shaft has come off and may very well been knocked around and possibly damaged beyond future use which means that you will need a new one and also
c) the shaft pin that holds the agitator gear in place has come out or been broken also
the fix is easy and your parts cost $ will be from $30.00 to $80.00 dollars depending on which parts you need. Now before you get palpitations, cost are listed as a possible need
1 new planetary $30.00, you may not need
2 new agitator shaft and gear assembly $27.00, pretty sure that you need but maybe not
3 new gasket $6.00
4 new gear grease $6.00 KA says 2 oz. (don't buy a 2lb (26.00 bucks) can when you only need 2 oz).
Without more clarity or a picture I can't help further. but before you start tearing you machine apart go to the KA website and get a parts list for your mixer
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD
let us know how you fare on this or better yet get us a little more info and we can help more.
Apr 17, 2013 | KitchenAid KP2671 Professional 6 Series...
BBeater scraping back bottom of bowl
Is the planetary still off before the taper pin is in place?
It's a shot in the dark but if everything lines up, I can think of two possibilities:
1. The taper pin in backwards, and
2. The shaft hole in the planetary is out of round.
Mar 20, 2017 | Hobart N50 Stand Mixer
Planetary housing fell off
BRUCE, sorry for the initial solution... I had a total brain cramp of what you were describing and after reflecting on your original problem and then seeing your second entry realized what happened. You are absolutely correct that the planetary shaft is press fit onto the planetary housing. For whatever reason, I overlooked that.
I cannot explain why it the housing came of the shaft, but suspect that vibrations during its use caused the fitting to loosen and the planetary housing to fall off.
You have two options. Option #1) Purchase a new planetary assembly that includes the agitator shaft, which will run between $35~$57, plus S&H depending on the vendor or Option #2) try to reattach the planetary housing back onto planetary shaft. (BTW, if you reorder the planetary use the part number from your Parts List manual for your particular color and model, not the 9078036 number you found on the housing)
I suspect the planetary housing’s spline well has already been weakened and there may be micro-cracking which is not clearly evident so the refitting may or may not work. Of course it may be worth trying and fit back together without any problems.
Since it will be difficult to get good mechanical advantage by hitting the planetary housing back onto the planetary shaft while the mixer is upright, you will need to remove the planetary shaft from the transmission housing before you attempt to hammer the shaft back onto the planetary housing.
If you attempt to refit the planetary shaft back to its housing, place the housing on a piece of soft wood to protect the enamel paint before you start to hammer the shaft. Also use a piece of wood on the top of the shaft so you don’t accidentally damage the top of the shaft with your hammer. Good luck. I hope this solution was more helpful than my first one. – hslincoln, Burke, VA -
Feb 26, 2010 | KitchenAid KP2671 Professional 6 Series...
I have a t801 mixer with a bent planetary shaft.
Remove the whole planetary from the bottom... There should be a large nut on the main shaft...remove it ....whole assembly drops down...careful...don't drop it......At the top of the bent shaft you should see some center punches holding a thin nut in place.....drill them slightly so you can loosen the nut. There are some studs that hold the lower bushings in place...remove them with a straight blade that fits the screw snug. You can have a new shaft made out of stress proof steel shafting from a competent machine shop........MONSTROSPIZZA.COM
Jan 29, 2010 | Hobart Food Mixers
How do you change or add oil to a Hobart H600 mixer
there are two oils to change. one for the trans. and one for the planetary.the drain plug for the trans. oil should be in back of the planetary take out plug let oil drain ,remove top cover take outstand off where front screw to top cover threads into put new oil in there till you hit line in sight glass on right side of mixer.
Jan 02, 2010 | Hobart H600 Stand Mixer
Trying to find what the shaft assembly looks like on a Hobart H600 Mixer
b1sam - You might try using the very easy "Hobart" smartparts webapp on the Hobart website. Cut and paste this into your browser Address line: http://catserv1.itwfeg.com/Hobart-Root/assynode.cfm From there you can select from 19 assemblies to review. Each assembly includes a parts list and an exploded view of the assembly. Based on your comment 'shaft assembly', I believe you want to look at either #12, Transmission Unit or #13, Planetary Unit.
Good Luck... I hope this is helpful.
Howard, Burke, VA
Nov 19, 2009 | Hobart H600 Stand Mixer
Oil leak from planetary
The transmission center shaft seal/chimney is bad.You need to tear the transmission down in order to repair,let me know.
Apr 29, 2009 | Hobart H600 Stand Mixer
Agitator Shaft in Planetary
You need to carefully tap out the pin that goes through the gear and the shaft to remove it, You can find the parts list by entering your model number HERE.
Aug 23, 2008 | KitchenAid KP2671 Professional 6 Series...
Hobart D300 Stand Mixer Logo
178 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
