Kitchen Aid undercounted iced maker. Model # KUIC15PHZS0. It overfills the water pan and excess water in the ice bucket. The drain pump removes the water but repeated process melts all the ice.
If your KitchenAid under-counter ice maker is cycling water but then powers off with the power button flashing several times, there may be a few possible causes. Here are some steps to troubleshoot the issue:
Check the water supply: Make sure that the water supply line is properly connected and the water is flowing to the ice maker. If the water supply is blocked or not reaching the ice maker, it may not be able to function properly.
Clean the condenser coils: Dirty condenser coils can cause the ice maker to overheat and shut off. Make sure to clean the coils regularly to prevent this issue.
Check the drain pump: If the drain pump is not functioning properly, the ice maker may shut off to prevent water from overflowing. Check the drain pump for any clogs or damage and replace it if necessary.
Check the water inlet valve: The water inlet valve is responsible for letting water into the ice maker. If it is not functioning properly, the ice maker may shut off. Test the valve for continuity using a multimeter and replace it if necessary.
Check the control board: If all other components are functioning properly, the issue may be with the control board. Test the control board for proper voltage and replace it if necessary.
If these troubleshooting steps do not resolve the issue, it may be necessary to call a professional technician to diagnose and repair the problem with your KitchenAid under-counter ice maker.
Did the ice buildup appear to resemble the water overfilling the top of the ice maker? The only thing that I believe that may work is removing the ice maker, clean the excess ice buildup.dry and reinstall the ice maker and see it works. If the ice is above the normal level the ice can cause the motor that pushes the ice out of its slots to strain more than the gears or motor can handle stripping the gear or damaging the motor beyond repair, When harvest takes place the first thing that happens is a heater below the ice maker warms the cubes a little just enough to allow them to slide out of their slots and fall into the ice bin. The ice make for your model does not have replaceable parts and if bad or damaged it is less expensive and time consuming to by a new ice maker. If the water fills above the top of the ice maker it is usually the fault of the water control valve not closing all the way once it fills the ice maker after each harvest. Did water refill the ice maker when you cleaned it? Did the water overfill after you cleaned out the ice maker? What I am asking is water over filling ice maker again after you cleaned out the excess ice? If the water continues to flow from the WR57X10032 Water Inlet Valve
most likely the recirculating pump is jammed or has failed... ive been in service industry for 18 years and actually have a kitchen aid stainless steel ice machine myself.... if you get into unit and remove the resorvoir and white plastic shield around pump which is located on right side normally.. then there is 3 1/4 inch screws to remove from the pump and the water line usually attached on side of pump plate just unsnap... unplug the molex plug and pull out... you can check impellar for scaling and or build up turn with hand.. if you think you free it up clean real well and test with a power cord while out. you will have to rig something to the molex plug and plug into a 110 outlet and test... if it is bad get you a new one and replace.... this is a common problem ...good luck to you
You have a restriction in the drain line beyond the ice machine and the water is backing up into the unit. You can try some Drain-o or snake the drain.
it's gonna be either the water valve or the gear shaft in the ice maker. replacement ice maker $130.00 water valve $40.00. gear only comes in with module $90.00. low water pressure from plugged water filter can cause this or if a reverse osmosis system is hooked to it. 40 pounds or more is reccomened for the valve to work properly
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tubemay be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey basterwill usually clear it out. Flushing
it out with hot water and clorox may help. Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
if you can move everything out unplug it ,turn it off w/ doors open,you can put pans of hot water in the freezer to speed up the process 12 to 24 hrs this will free up any clogged tubes.After its completely defrosted Only turn it up to 4 or 5. Good luck.
hi my name is mark, do you have a water filter on this unit. shut off water to ice maker. remove water line from ice maker, hold water line in a bucket slowly turn on water. if you get water. then the fill solinoid has failed. if you do not get water trace water line back to water shut off. if it is the solinoid valve. you will need model and serial number to order part
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
https://www.repairclinic.com/PartDetail/...
