Question about GE DBSR453EBWW Electric Dryer
Crosley dryer Dryer was working great then after my last load would not do antyhing
  • 447 Answers
They have special thermal fuses that when the dryer gets too hot then shut the whole thing down. Sounds like what youve said has happened
Posted on Nov 19, 2007
Crosley gas dryer will not work
Probably caused by failure of a cheap chinese control board. In fact, failure-prone chinese control boards are at the heart of virtually all premature failures of modern appliances. They usually only last just long enough to span the warranty period.
May 30, 2014 | Crosley Dryers
Apartment size washer dryer. I have the chance to
Formed in 1976 in Winston-Salem, NC, the Crosley Corporation consists of a group of independently owned distributors who resurrected the Crosley trade name and introduced a line of refrigerators, freezers, ranges, dishwashers, air conditioners, and other appliances. We carried the heritage of such features as "Shelvador" and "Conservator" that were marketed for decades.
Sep 27, 2013 | Crosley Dryers
Dryer wont turn on
Lots of things it could be. I'd try the shut-off switch first.
There is a switch that is supposed to turn off the dryer when you open the door.
That switch is often made of plastic, and can break or even fall out inside the machine.
After that, I'd check the start switch to see if it failed.
Be blessed.
Feb 17, 2013 | Crosley CDE6000 Electric Dryer
Dryer worked great yesterday , today no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Feb 06, 2011 | Crosley CDE6000 Electric Dryer
My electric dryer is a crosley conservator-- looks like a wide front door front load dryer and it will not start. The timer button works but nothing else. It is 3-4 years old. There was no odors or any...
While this could be any number of things it sounds like for whatever reason the heating element is not working. If a thermostat fails it will not allow the machine to work for safety reasons. However, I had a problem with excess moisture getting into my circuitry and it would not work until I let it dry out. I had to flip the circuit breaker off for quite some time until it dried out and it finally worked. I could cheat the process a bit by using a hair dryer to speed up the circuit panel drying time. In the end after finally finding which electronic button was the culprit I was able to spray WD40 on the affected button to help keep it dried out.
So, try letting it sit for a few hours and if it works after that it is moisture getting into the circuitry. If it does not work after that it is either the heating element or one of the thermostats. You can Ohm these out to check them if you need to. Let me know if it starts working after setting or if you need to check the readings on other parts.
Nov 21, 2010 | Crosley CDE6000 Electric Dryer
My crosley dryer stopped in the middle of a load and now it will not turn back on!!!
if it's an electric dryer, it may have tripped the circuit breaker.
Jul 20, 2009 | Crosley Dryers
Crosley cde6500w dryer has power will not work.
check the cord, check the safety switch on door. any internal fuse? last check section switch
Jun 24, 2009 | Crosley CDE6000 Electric Dryer
CDE6000W, Crosley dryer stopped working in middle of load
it could just be the motor going out some dryers only last 6-8 yrs some dryers continue to be quite even if there going out i suggest call a repair preson to see if repairing it is worth it
Here To Help
Nov 17, 2008 | Crosley CDE6000 Electric Dryer
GE DBSR453EBWW Electric Dryer Logo
55 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
