Ecoquest Fresh Air Air Purifier
Problem for Ecoquest Fresh Air Air Purifier
NEED A CIRCUIT CARD FOR LIVING AIR BY ECOQUEST..
By memomduff1 on Jul 19, 2009
NEED A CIRCUIT CARD FOR LIVING AIR BY ECOQUEST.. WHERE CAN I FIND ONE?
Best Solution
posted on Oct 19, 2009
Very Helpful)
MrsRDC
Rank: Apprentice
Rating: 100%, 1 votes
Try checking each of the individual little pieces on the circuit board. You might have some 'gunk', grease or whatever that is clotting a connection. Try GENTLY using a bamboo skewer to clear any obstruction. You may find that 1 of your connections is bad. Take the board to a 'space junk' store that will probably have a replacement part for you. It should be installed using a micro-soldering kit, but you might have a buddy who assembles computer boards - - - or someone familiar with old fashioned circuit boards as in a radio, etc. who can help you in replacing it.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Great Idea! Thanks " - memomduff1
Solution #2
posted on Jul 23, 2009
Not Rated)
Dutch7773
Rank: Wiz
Rating: 84%, 15 votes
Circuit boards are not sold separately as far as I know. Best is to call EcoQuest and to ask what it would cost to repair. Or you could try your luck on Craigs list or ebay and buy an older model for parts.
Dutch
Was this helpful?
Yes
No
Popular Solutions for Ecoquest Fresh Air Air
Questions and Unsolved Problems for Ecoquest Fresh Air Air
Do you recommend Ecoquest Fresh Air Air Purifier?
Answer
Answer
I re[laced the lamp and charge on my Fresh Air purifier and the display still says replace lamp. Whi... (More)
Answer
Do I need a new fan blade if I replace the fan or will the old one go back on fairly easy? Ecoquest... (More)
Answer
I have 2 ecoquest fresh purifiers 1 will not power on would that be a fuse issue and the 2nd the... (More)
Answer
install plate? no i just cleaned and now it won't work. it says to install plate.
Answer
unit cut off about every 2 minent then come back on
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ecoquest Fresh Air Air...:
Top Air Purifier Experts
Rank: Guru Guru
Solutions: 2520
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Air Purifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
