TWO answers read and follow the Manufacturers Specification. OR Always use ** 15-40 Diesel Rated Oil is ALL gas, natural/propane and diesel Engines! Use Purolator, then WIX, then Manufacturers Filters - NEVER Fram, "special". oil the oil lube shops filters!!! WHY? When flying planes, every 100 hours I remove the filter, cut it open, and INSPECT the filter material for particulate. My Vehicle Engines go for well over 600,000 miles - most other peoples. simply do NOT!
** I use Delo 15-40 in everything - an better one is Shell Rotunda, however too expensive and not needed! In gas engines after 500 miles, the FIRST Time ONLY - Replace the oil AND FILTER - mixed fuels and oils NEVER mix well. Then on gas engines ONLY replace the filter at the "normal" intervals and ADD not change, the oil... On Diesels, due to the extreme compression, you DO change the oil, at "normal" intervals. In gas, NOT diesel engines - you could use Pep Boys and/or Walmart's generic DIESEL GRADE oil - NOT in diesel engines, as from my experience.
AVOID gasohol - unless you like flash rust and oxidation inside your engine AND 30% less fuel mileage - NEVER use WD40 on ANY metal you want to reuse! And do NOT use BP or unknown small time gas stations - as MANY "top off their fuels" with other octanes - which LOWERS the octane - do to "covalent bonding of carbon molecules" Example: a 50/50 mix of 100 octane with 90 = closer to 80 NOT "in the middle". LEHenson.com
SOURCE: steps for replacing wiper motor for 1998 VW Jetta
remove wipers. remove plastic covering by loosening plastic screws first. unplug wiper motor wires. there are about three 10mm nuts at the motor location and you also have to unscrew the big nuts that were below the wipers when you unscrewed them. replacement is reversal.
SOURCE: Oil change for 1996 Jetta
IT USUALLY DEPENDS ON THE SEASON AND THE WAY YOUR CAR IS RUNNING BUT I'D RECOMMEND 10W40 FOR THE SUMMER.
SOURCE: 2006 vw jetta tdi service engine light reset
With the key in the ignition (but not turned), press and hold the Odometer Reset Button on the right hand side of the panel. While still holding that button, turn the key (although not far enough to start the engine) and then press and hold the Minute button on the left side of the instrument pane(if pressing doesnt work try turning the knob clockwise until service light has gone off and skip the pressing)l. Release both buttons at the same time.
SOURCE: 2004 VW Jetta engine compartment fuze box location
one is located over the battery, the other is located in the side of the dash.
First panel:
If you pop your hood the battery will be on your right sid in the front of the engine bay. There is a small rectangular piece on top of the battery with a lot of heavy guage red wires going to it. That is the engine bay fuse box.
Second panel:
if you open your driver side car door it's under neath a panel located inbetween the door and the dash board.
