Question about Brother IntelliFAX 2800 Laser Fax
I think it nees cleaning but how and what?
It produces gray poor quality with horizonal dk areas and vertical light lines
  • Brother Master
  • 1,113 Answers
Re: I think it nees cleaning but how and what?
This can be two things drum or toner more likely needs new drum, nothing to clean really except slidy blue tab on drum that slides up and down it cleans carona, fix for "vertical white lines"
Posted on Nov 19, 2007
0 characters
3 Points
Sometimes my transmission reports say poor line condition att says my line is ok any ideas?
Unless you are paying for a "facsimile" line...the odds are that you are paying for a phone line and using a fax on it. The responsibility of ATT is to provide you with a line which meets phone quality. If you are getting errors due to occassional poor line connections these may not even be due to poor lines in your local area. See about getting your fax set to allow more "error" pecentage to be received before giving errors...probably need a service man for that adjustment tho".
Oct 11, 2010 | Brother Fax Machines
Print quality
Sounds like the scanner led head. Try to look in under the scanner when doing a copy to see if it is fully lit, can be a pig to rplace, some brother parts are not too expensive but you will need an engineer to order it and fit it
May 12, 2009 | Brother Fax Machines
Print Quality Problem with Brother 2820 Fax
sounds like you are using generic drum and toner. try OEM (brother brand). you say copies are coming out completely gray. try printing an internal report from the control panel. if that is gray or received faxes are gray, then the problem is not in your scanner area, and i would wager you are using "generic" supplies.
Apr 10, 2009 | Brother IntelliFax-2820 Laser Fax
Dark vertical lines
You have to clean the scanner.Open the dock feeder area,and make sure the scanner glass is clean sometimes the glass look clean but just a smaal dot on the glass can cause a line.Clean also the white area above the scanner.The white area above the scanner help for shading operation of the mchine.Make sure you clean with a sullotion that can remove ink but not damage plastic.
Feb 18, 2009 | Brother FAX-8070P Plain Paper Laser
Poor fax printout quality
I would say you have a bad drum / toner cartridge.
Stuff you receive with vertical lines is probably the sender's dirty scanner.
Nov 04, 2008 | Canon LaserClass 2060P Plain Paper Fax
Gray line down middle of faxes/copies on panafax uf880
yes change a toner and clean the glass area under nearth the toner.
Oct 24, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
Here is the scoop! There are two (2) components to the fax machine, one is the scanner portion which is located just past where the paper you are copying or faxing enters the machine, separate the two sides and access the imaging plate, clean this area with denatured alcohol.
Step two is to clean the toner and drum unit, get the mirror at the back of the toner and under the toner. If after this you are still getting lines on the prints you will have to replace the drum unit KX FA-84 about $85. Happy faxing, Ken
May 15, 2008 | Fax Machines
Copies and outgoing fax quality
your machine most likely has toner spills in it.
if you send faxes face side down follow these instructions ;
1- take out toner
2- look for thin glass strip on bottom inside the machine
3-wipe clean
if you make copies side up then do the same except look for glass strip on the upper side of machine
Nov 27, 2007 | Brother IntelliFAX 4100 Laser Fax
Barrel on printer area leaves a vertical line
Not sure what you mean as barrel, Is the line present when receiving fax's/printing reports or just when doing a copy? Does it only do it when using doc feeder, if it is only 6months old then is under warranty
Oct 17, 2007 | Brother IntelliFax-2480C Fax
Incoming fax quality
Are you using genuine Brother supplies? Generic supplies are the main reason for print quality issues. Have you ever changed thr drum unit ? Expensive! You can buy a new machine and get a new drum and toner for a little bit more.
Oct 22, 2006 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
127 people viewed this question
Top Brother Fax Machines Experts
Paul King
Paul King
john archer
Are you a Brother Fax Machine Expert? Answer questions, earn points and help others
