Question about Electrolux EW30EW65SS Stainless Steel (Electric) Double Oven
Grease between the multiple layers of glass windows on oven door
I accidentally dropped a piece of chicken and it fell on the bottom of the oven door that was open.  Somehow some of the drippings got in between the outermost layer of glass that is actually built into the oven door and the next layer of 4 layers of glass.  I can get the inner most piece of glass out, but cannot figure out how to get the next two layers out so that I can finally get to the worst piece.  I'm afraid that I might break the two inner layers that some next.
2 Suggested Answers
  • 2651 Answers
glass is glass. wouldn't say its normal but not an unheard of complaint, YOu purchased an ICON, id call the manufacture, wouldnt be suprised if htey took care of that for you! thats their pride and joy!!!!!
Posted on Mar 01, 2008
Need to reattach glass panel on oven door
You may have to contact Bosch directly to obtain a diagram and/or instructions.
Aug 27, 2017 | Bosch Ovens
Range/Stove/ Oven Door Glass Replacement
I see many questions come up at about oven door glass that has broken and how to replace the glass. For many ovens it is a relatively simple task. It will take about an hour for most people, depending on the skill level, and the type of door.
To do this job you should have handy a screwdriver, usually a Philips head medium sized, a plastic tarp, especially if your glass in the door is already broken, and of course the new glass. It is also a good idea to measure the new piece of glass to make sure that it is close in size before taking the door apart.
For your safety, make sure that the power is turned off to the oven before starting this job also. The open the oven door and remove the screws on the inside face of the door. If the door can be remove easily you can remove it, but it is not necessary to do that. Make sure that you place the pieces of the door as they come off and the screws in a place to keep them organized for when you put everything back together.
For most ovens you will find the oven glass held in by tabs, similar to a picture frame. Pull the tabs back to release the glass. Carefully remove the old glass from the frame. If it is broken, be very careful not to cut yourself. Also contain the glass on the trap to make cleanup easier. For many newer ovens, you will have three layers of glass. Do the same process for each layer.
When the old glass is removed, then simply replace each layer of glass and press the tabs back in place for each one. Then replace the brackets or inside pieces of the door, and secure with the screws.
This is how easy it is to replace the glass for many of the ovens.
Another word about broken glass in ovens…..
Many of the people that have broken glass state that it broke after running the self-clean feature of their oven. For many of you this warning will be too late…but for those of you that see this before, be warned!
on Mar 22, 2010 | Ovens
How do i clean between glass doors on bottom oven of fagor fb1982x4 ?
disassemble door , clean glass , reassemble. door.
Jul 27, 2014 | Fagor Ovens
Outside door glass has slid down
Sounds like the door gasket/seal has pulled away from the rest of the door frame and layers. You might be able to take the door off of the hinges, and cabinet, and take apart the layers to readjust.
Dec 26, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have a ken more elite double oven. I set it for 425 for 30 min and was to turn it back. I am cooking a chicken. I didn't have my glasses on and accidentally turned the flex and clean on. Now
sure you'll be able to open it but your chicken will be burnt to a crisp. actually, it may not if you just hit cancel right away after starting the self clean feature.
Nov 14, 2012 | Ovens
How to clean the inside of the glass door of Electrolux Wall Oven
I scoured the internet trying to find how to clean inside the glass of my Electolux Icon double wall ovens. Short of "The Big Q-tip" method (which only made a smeared mess) I didn't find anything. So I went ahead and started taking the doors apart. I'm happy to report I just finished with fantastic results. So I'm going to do a step by step, I know I would have appreciated reading instructions for it. It's very easy but time consuming. You'll need a large work area because there are actually 4 sheets of glass, a Philips screwdriver, and a straight razor with handle.
Refer to your manual on how to take the doors off - but it's very easy. Simply open the door, flip the locks toward you and pull up and out at the same time. Be careful...the door is very heavy.
Lay door on blanket or towel, especially if it's stainless steel. There are 4 screws along each side of the door. The 2 screws that hold the hinge at the bottom are smaller than the 2 closer to the top.
On the very bottom there are two more screws to hold the bottom outer frame. Under that piece are 2 more screws that hold the inner bottom frame. That's it. Slide out the hinges and you're ready to go.
Remove those 2 frame pieces and keep in mind how they fit back together. Remove the top piece of glass and put on another towel. Now I'm not sure if it matters but I was mindful of the side of each piece of glass as I remove and cleaned them to make sure they went back exactly as they came out.
The first piece is going to be the most time consuming to clean. One took me over an hour. The grease is hard to get off because it just spreads around. I found a straight razor really sped this along, just make sure you always use the razor on wet glass or you'll scratch the glass. It's fiddly...just keep at it. I also used mineral spirits to help degrease. When done I laid this on the dining table.
The next 2 pieces of glass are in a frame that comes out together. The frame is only on the sides so be careful it doesn't come apart on you when carrying it. Inside the frame piece is a rubber gasket to separate the 2 pieces of glass. Watch how the frame comes off, there is a wide and a narrow side. It's easier to take off the frame piece and simply lift of the first piece of glass. The bottom piece of glass sits in a channel of the rubber gasket.
Pretty simple. Lots of elbow grease if you cook a lot. Reverse the order to reassemble. One thing to note - on the door sides near the top, you'll see a silver metal piece inside the black frame. Make sure the screw holes are visible thru the black frame. I have very small fingers so it was easy to do it with my fingers but I would imagine someone with large hands will have some difficulty. Also, when screwing the hinge in place I had to twist the hinge so the screw hold was up against the black frame. The screws are so short that they'll just spin without catching if you don't.
Happy cleaning!
Mar 21, 2009 | Electrolux EW30EW65SS Stainless Steel...
Grease in between glass on oven door
You have 2 pieces of glass that are separated by a frame then sealed. What has happened the seal has been broken and thus allowing air and grease inside. You can take it apart but the grease will come back, or you can buy a repalcement glass and be done with it. The question is, do you want to go to the trouble of cleaning the glass (1-2 hours of disassembly and assembly) probably once every 2 months depending on how often you use the oven, or buy a new one and it will always be clean. One caution, cleaning the glass periodically weakens and flexes the metal frame or band thus making it harder to properly seat the glass.
Feb 22, 2009 | Kenmore 47783 Electric Single Oven
Glass in oven door is cracked, inner glass completely fallen out
this is a fairly common problem with glass doors on any make of oven
Oct 21, 2008 | Whirlpool RBS305PD Electric Single Oven
Clean between door window panels
Sorry this is the only way to clean in there but if you take the door completely off and set it on a drop cloth Then take it apart it makes it a little easier
Jan 26, 2008 | Whirlpool GBD277PD Electric Double Oven
Electrolux EW30EW65SS Stainless Steel (Electric) Double Oven Logo
42 people viewed this question
Top Electrolux Ovens Experts
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
