Question about Candy Ovens
Candy P6N not hot
Our electric built in Candy P6N is over 3 years old and now never seems to get as hot as it should do. It now takes longer to cook things and although it still heats up, it never reaches max temperature.
Any ideas ?
Rotu
  • 175 Answers
SOURCE: taking way too long to heat
Usually when an oven is slow to heat, it is because of a bad element. You can look at the upper (broil) and lower(bake) and see if they appear to have any major burn marks on them, It may just look like something spilled on it untill you look closer or try to clean it off. if you do not find any obvious problems, turn the oven on and wait a fem minutes, then see if the bake element is glowing. Also look at the broil element, they should both be glowing at least a little orange. Compare how it works to the other oven that works properly. If only one of your elements is glowing, either you have a bad element (which is usually apparent on visual inspection) or a bad relay board that controls the element. The element is easy to change, onlt a couple screws and 2 wires (turn off the breaker first!!), the relay board is pricey, and a pain in the tookas. if you decide to guess, try the element first. Hope this is at least a little helpful.
Posted on Jul 01, 2007
yalmer
  • 552 Answers
SOURCE: Oven wont heat up properly
This may be the thermostat control.
I would find someone to check the resistance of the element with an ohm meter.
It should read 15 to 20 ohms.
Put the timer on manual first and try the oven, because it could be the timer.
It would be ok to just replace the bottom oven element because most of the time it is a faulty element.
Posted on Feb 12, 2008
  • 5 Answers
SOURCE: I have electric double oven VEDO275SS by Viking
you need to have a new thermostat fitted or the old one re callibrated if possible
Posted on May 29, 2009
fixyourboard
  • 310 Answers
SOURCE: I need to calibrate an electric oven
Probably. There is often a key sequence that will enable a calibration mode. We need the full model number to find the tech info, or you can probably find it in the tech sheet which is normally taped on behind the control panel.
Posted on Oct 14, 2009
barkencoa
  • 3463 Answers
SOURCE: Heat escaping, uneven baking, longer cooking times
Either the seals need to be replaced, or you may have weak oven door hinges, and the door is not closing properly.
Only solution would be to replace both hinges if this is the case.
Please rate my solution.
Thankyou.
Posted on Feb 01, 2010
Candy Built in double fan oven bottom oven not getting hot
Cheak the coils. Do a continuity test also look for signs of an electrical short(small scorched area) and clean the contact where the coil attaches to the appliance.
Apr 17, 2014 | Candy Ovens
My GE #JRP15WOP2WG wall oven, manufactured in about 1995, only starts heating if I put the temp at 550. It gets extremely hot, then I have to turn it down to 520 in order for it to click off. Unfort
Good Morning! I would check the oven temperature sensor first. There are a lot tutorial videos that can be found by Googleing, "How to test my oven temperature sensor." If the sensor is good, and reads 1100 ohms at room temperature.. then the issue youre experiencing is likely control board related. Given that the part is no longer available new, the oven board will have to be rebuilt. Fixyourboard does this and offers a 2 year warranty with each remanufacture.
WB27K5073 GE General Electric Oven Control
May 14, 2017 | GE 30" Built-In Single Electric Wall Oven...
I have a KitchenAid Superba KEMC308KSS0 that is about 9 years old. In the past few months it has been cooking really slowly. Whereas in the past, in convection mode, things cooked faster than...
I have a Superba built-in YKEBS 177 D56 ( dual convection/convention)...I think it might be about 10 years old. I noticed the same thing starting last year..the temperature seems a litlle off and the cook time on the convention seems to take longer. I've never used the conventional oven so I don't know if the temperature is OK on that component.
I don't have a manual. and I've been searching for it...does anyone know which one I need?
Sorry I couldn't help with your problem, mine is similar to your though!!
Jan 22, 2011 | KitchenAid KEMC308K Double Oven
Oven not properly heating
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 06, 2010 | Viking 30" Professional Select Built-in...
Thankyou.
Feb 01, 2010 | Neff U1421 Double circotherm Electric Oven
Oven staying hot a long time after it was turned off
Thanks for your reply. I contacted an appliance repair person I have used before and he told me about turning off the breaker, which I did. He suggested using an oven thermostat to see if it was heating to the correct temperature as a first step. It may be the thermostat, I do not know what the controller is as presented by one of the responders. At any rate I learned that my breaker for the oven is by itself and is not attached to the stovetop which is good. I will have to weigh the cost of replacing a part on a 20 year old builder quality oven with microwave on top to a new one. Any ideas on a new problem free model are appreciated!!
Feb 12, 2008 | Ovens
Ovens Logo
Top Candy Ovens Experts
ashburton
ray gallant
Dado
Are you a Candy Oven Expert? Answer questions, earn points and help others
