Question about Tomtom GO GPS Receiver
Signal my unit cuts out more often than not with no signal sign on,grey screen! Takes 10 mins or more to recieve signal when put in car on start of journey
    Brigadier General:
  • 4,090 Answers
Needsa a replacement battery
Posted on Jul 22, 2009
Starts and cuts off
serial number/keygen for registry reviver
Jan 28, 2014 | Cars & Trucks
Hi my c1 has started to make a whining sound (bit like a dog whine) the last couple of days. It tends to get louder and is intermittent, it starts when the engine is fired up (no probs starting engine)...
Have your drive belt replaced (sometimes called the auxiliary or serpentine belt) when it slips it creates a screeching noise and it's also a sign that it's going to fail (snap).
These can run the alternator and power steering so you should change it as a preventative measure.
Oct 17, 2013 | 2008 Citroen C1 1.0
I have recently installed 1Te Voltas 2 star A.C. I need clarification on the following 1) In cool mode, what is system of auto cut. Suppose I put on remove temp 27deg C. Temp of the room goes up to 26 deg...
Dear Mahesh
In Cool Mode
Temp Diff - + - 1 deg C in Room Temp & Set Temp
This is auto cut
In Dry Mode
Comp Runs for 10 mins then get off for 5 mins then again get on for 10 mins this cycle continuues.
Oct 15, 2013 | Whirlpool ACQ158XP Wall/Window Air...
While driving noticed check engine light ,slip,and ect light on dash came on proceeded my journey , when i started up the car again it took several cranks before starting. Next day drove about half a mile...
the bank#1 cam position sensor has failed.this is located in the back of the cyl. head closest to fire wall.takes several attempts to start because lack of signal puts ecm in fail safe mode and it substitutes a value to get engine started.about a$100 for sensor and half hour to put it in.
Jan 19, 2011 | 2004 Nissan Quest
Car not starting - Intermittent
intermitten problems are the worse, when it wont start check fuel pressure with a gauge, and then check for spark, i have spent days on problems such as this, what you have to find is what is missing, fuel ,spark, is maybe coolant leaking into one or more cyls, i have seen air in the fuel system that only cause problems when under hood temp is high, open the hood and it cools enough to to start, hope this helps
May 05, 2010 | Hyundai Motor 1998 Accent
Tom Tom loses GPS reception as I am driving around
Have you hooked your GPS to an internet connected computer lately?
The TomTom home software that comes with the GPS will update so that it knows were the satalites are for the next week. It will also update the software to the latest verson.
You could also try inserting the end of a paperclip in the reset hole on the bottom of the GPS unit.
If all this fails contact TomTom. I have found them very helpfull.
Jul 12, 2009 | Tomtom ONE GPS Receiver
Tv takes 30 min to cut on... but when it does no picture shows.
LOL sounds like you just need a new TV buddy, there are multiple components that are going out, first start with the green lines or "pixelations" these are caused by the tv no longer being able to regulate the electricity in those pixles and are as a result 'Open'. The 10 minute things is more of a energy conversion thing and sound and video on and off are connection issues (internally) so take it to a repair shop but if the price to fix is greater than 1,000 you should be willing to scrap it for a replacement. who knows the shop might buy it off you for cheap...
Good Luck
This is my Fav...
pricey though but can keep an eye on ebay for half price divorces.. :D
http://www.samsung.com/us/consumer/detail/spec.do?group=televisions&type=televisions&subtype=lcdtv&model_cd=LN52A750R1FXZA&fullspec=F
oh and my site
www.hoosierpcrepair.com
Jun 22, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Freelander cuts out a soon as you touch the throttle after starting and will not start again till 10 to 20 mins after is this an electrical fault? thanks
Try cleaning the fuel pump filter. the filter is on the bottom of the pump inside the tank.You get to the tank from under the seat behind the driver. Job takes 10 mins.
Mar 06, 2009 | 2002 Land Rover Freelander
Phone calls get cut off and fax goes into recieve mode
If you are using the fax as both for calls and receiving faxes make sure you have the fax set up to FAX/TEL mode. This should solve your problem.
May 22, 2008 | Canon FAXPHONE L80 Laser
Losing GPS signals.
i also have the same problem my gps loses the signal i left the unit on power for two days and still no signal please help.
Nov 26, 2007 | Fine Digital FineDrive 400 GPS Receiver
Tomtom GO GPS Receiver Logo
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
