Question about Logitech 967461-0120 Keyboard/Mouse
Logitech Keyboard Issue with @ sign
I have a Logitech Wireless Keyboard (not sure of model). When looking at the keys, the @ sign is not where it typically is over the 2. Instead, it's over on the right hand side along with three other symbols. I have tried "shift + @", "alt + @", and "control + @" and nothing is working. How do I get the @ symbol to appear when I type???
(Using a different keyboard to type this message).
3 Suggested Answers
  • 807 Answers
SOURCE: Switched Keyboard symbols
Go to control panel on start menu.You may have to click Classic View. Click Regional and Language options. Click middle tab at the top called Languages. Click the Details button. Click Add and select the English UK option from the drop down list. Apply and Ok.
Posted on Mar 05, 2008
  • 51 Answers
SOURCE: the keyboard types an english pound sign instead of a dollar sign
Go to settings and adjust the location and hot keys. of your keyboard go to control panel and to keyboard and adjust.
Posted on Feb 11, 2009
  • 1901 Answers
SOURCE: down arrow in lock symbol on keyboard. what is
That would be the Scroll Lock. Do you have a Scroll Lock key? Press it.
Thanks for using Fixya.
Posted on Oct 06, 2009
0 characters
1 Points
Will a Logitech Wireless Keyboard/Mouse (Y-RQ57) work with a USB-to-Keyboard/Mouse bus adaptor?
Hello Marecha--it can be a bit of a needle in a haystack situation when trying to use adapters to make older hardware work with the newer and faster things available these days. I've tried similar scenarios and with some I"ve had success and with others not so much. If at all possible I would recommend obtaining the adapter from Logitech themselves as many of the cheaper, generic imports are only manufactured to mimic a certain prototype and many aren't even tested. At the very least, just be sure that wherever you purchase the adapter is willing to exchange or refund for an incompatibility issue. Trying one (or several) won't hurt the hardware in any way. Good luck!
Apr 28, 2014 | Logitech Y-RQ53 Cordless Keyboard Wireless...
Using short-commands on wireless keyboard
You should first see if there are any optional settings you may have missed. If not, then go to and look for a newer device driver (SoftWare) for your model keyboard. Install SW upgrade. There is the (small) possibility of a problem in the keyboard, but more likely a driver issue..
Nov 08, 2013 | Keyboards & Mice
New wireless Logitech M320 keyboard works, but it cannot find the wireless mouse nor make it work. What do I do now?
First off, check your drivers and make sure they are up to date with your model. Next check the batteries in the mouse and keyboard, chances are if the mouse is out of juice, the keyboard may not be far behind. Thirdly, make sure you are following the correct procedures stated in the directions for "sync-ing" the mouse and keyboard with the wireless reciever!
Aug 31, 2011 | Logitech Wireless Access Duo Optical...
Hi I have a Logitech EX110 keyboard ... I would like to know the short cut keys for the Euro and Pound sign
For the € sign it should be AltGr + 4
I'm assuming that pound means £ (GBP) and not #...... Do you have the £ sign on the number 2 key? If you do and your just not getting the £ symbol when pressing Shift + 2 then you probably have the keyboard set to the wrong language.
In control panel look for Region and Language settings, in there should be keyboard languages. In that section make sure that you have the correct one selected for your keyboard.
May 09, 2011 | Logitech 9675020403 Keyboard
I am not a technical minded pensioner and have a CX100 keyboard and want to reprogramme some Hot Keys. Can someone tell me in non technical terms how to do it
Although I cant seem to find the model that you are using so I cannot confirm that it has programmable keys I would tell you that for a non technically minded person the best way to program a mouse or keyboard with logitech is threw there software. It will show you how to map different keys.
go there let it find your keyboard and then look for a compatible version of there setpoint software.
Aug 25, 2010 | Logitech Wireless Access Duo Optical...
How do I unlock a wireless keyboard
On the keyboard you will find a lock sign key on the kayboed press that one.
Jan 13, 2010 | HP USB Wireless Keyboard/Optical Mouse...
My logitech wireless keyboard won't type. i
go to logitech support, download setpoint software and follow instructions on setting secure connection. i just did it with mine and keyboard got fixed. your symptoms should be that the qwerty keys dont work but the multimedia, clock and function keys are working. the setpoint software will take care of that.
Nov 11, 2009 | Logitech Cordless Desktop MX3200 Laser...
Logitech keyboard 3 months old,wireless, cannot get anything to write, pressed connect buttons under keyboard and on moluse, please help
in logitech we get three thing 1/ mouse2/ keybowd 3/ usb senser if your ke bord is not working look battery of key oard and mouse 2/ your use port is suppor ting or not look on devious manager . if not able to contact . your goods is damage.
Jul 13, 2009 | Logitech 967437-0403 Keyboard
Getting full use of the keyboard
you may need to configure it. to do this, go to control panel, select "printers and other hardware, then click on "keyboards" and find your model.
Mar 28, 2009 | Logitech Wireless Access Duo Optical...
Wrong Keys
Go to "Start --> Preference --> Control Panel --> Keyboard" and see in what language is the keyboard assign. If you have tryed 2 keyboard at the same computer, and have the same problem you could have something wrong in the keyboard configuration.
Nov 10, 2007 | Logitech Wireless Access Duo Optical...
Logitech 967461-0120 Keyboard/Mouse Logo
94 people viewed this question
Top Logitech Keyboards & Mice Experts
micky dee
Are you a Logitech Keyboard and Mice Expert? Answer questions, earn points and help others
