I would like to print black with one color cartridge empty
MFC-465CN printer question. I would like to print a document in black only while one of the COLOR cartridges needs replacing. Can I bypass the INK EMPTY message and print the document? I tried selecting GRAYSCALE for the document but no luck.
    President:
  • 2,306 Answers
If you take the empty cartridge out and put a small piece of electrical tape over the little window on the front, the printer will think the ink is full.
Posted on Jul 20, 2009
Yellow is not appearing in my color printings
Often, when a color is not printing, or it is not showing the correct shade/color, it is because one or more of the color ink cartridges is low or empty. See if this happens when you use new ink cartridge(s)
Mar 03, 2014 | Brother MFC-465CN InkJet Printer
I have a Brother MFC-465CN and it says the Black Ink cartridge is empty. However, the cartridge is full. I cannot print until this is resolved - ow can I fix this?
Hello I am an expert on printers are pretty good Brother.Brother But the ink is running out fast .. I got home Brother MFC-210C.
So I took ink and slid ho.
. I hate Brother printers!. So I broke down and I saw that there is a color sensor and instead I chose colors I had crouched low and showed that the paper is full of the good? Try it at home if you can.
Jul 30, 2012 | Brother MFC 240C All-In-One InkJet Printer
My brother mfc 465CN wont print black only color
Have you tried cleaning the print head? Find the instructions in the troubleshooting and maintainance section of the manual here http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_465cn_EN_1269.PDF
Jun 04, 2010 | Brother MFC-465CN InkJet Printer
Out of color ink; won't print black and white.
The printer will need the colour ink to be replaced otherwise it will not print at all. You can try pressing the Start/Reset button but this will most likely not work and the only way forward is to have a colour cartridge with ink in it even though you may never use it!
Oct 07, 2009 | Brother MFC-465CN InkJet Printer
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
I'm out of magenta ink and want to print in black and white. If I select grayscale, I still can't print.
Please look at the following link, it will explain as to why you cannot print when just one color is empty.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000009533&Sympt=Why+can%27t+I+print+anything+if+only+one+of+the+ink+cartridges+are+empty%3f&Model=1230&ProductGroup=5&ProductID=
Aug 02, 2009 | Brother MFC-465CN InkJet Printer
Will no print black color doc if any other color ink is empty
actually, its not. the reason is, there is a small resovoire (sp?) in the ink cartridges. if you continue to print, the nozzles will clog up, and can cause all the nozzles not to work. even when you do just black, the printer has to clean at times all the nozzles and if your nozzles are empty, air will go into the deep and dry up the excess ink.
if you are going to do primarily black prints, you should get a black and white laser for those uses only.
Jun 13, 2009 | Brother MFC 420CN All-In-One InkJet...
Brother mfc 465cn printer
If you remove the empty cartridge, you will see a small window on the egde that plugs into the printer, in the center. This is where the printer optically scans for ink levels. On the empty color cart, you can try covering that raised spline with electrical tape or by coloring it with a black permanent marker. That should fool the sensor into thinking your ink is full.
Oct 31, 2008 | Brother MFC-465CN InkJet Printer
Black cartridge doesn't print
you need to do a hard reset on the printer as well it might clear up the problem and recognize the ink at its proper levels.
refer to your user manual or let us know and we will find the procedure to do so.
i have a similar model and know how picky they can be.
Aug 03, 2008 | Brother MFC 420CN All-In-One InkJet...
462 people viewed this question
jasbo
jasbo
