Question about Ovens
ERROR F6 I have a Vertical oven Model HMV24CEWBBB with electronic ignition that show F6 in the screen. How can I solve this problem? because the alarm do not stop to buzz until I disconnect the oven. Also the buttons in the control pannel do not respond. In the front of the oven show MABE as builder, but in the label show ROPER Corp.
  • 6,784 Answers
HI, the reason for the non responsive control is being caused by a major fault within the control circuits. the entire control board will need to be replaced. it has failed at this point.
Replacing the Oven control board will solve this issue.
Posted on Jul 21, 2009
The F1 error code is lite and alarm noise won't shut off. turned off breakers and the alarm stopped upon turning back on but F1 lite is lite.
With your model & Serial number you should be till able to order the EOC (Electronic oven control). But they are not cheap.
Mar 17, 2015 | Ovens
Error code F6E0 on Kitchenaid KGSS907000 wondering if it is the control board or touch screen, what other components could cause this?
F6 - E0 Return line not connected If switch pulse return line is not connected, electronic control will display F6 within 60 seconds after power up. Replace control board
May 02, 2014 | KitchenAid Architect Series KEBC107KSS...
F6 E6 error code?
This fault is a communication error at the appliance manager, could be a loose wire or a bad display transformer, either way you will need a certified technician to fix this issue, there is no simple plug and go issue to resolve. I personally found the problem to be the transformer not send voltage to the appliance manager. This is solvable but needs someone who understand electronics to correct this issue.
F6 E0 Oven user interface - lost communication E6 Oven appliance manager 1 (upper, single) - lost communication
This is directly from the tech sheet of your oven and directly from the factory web site.
Good Luck
Dec 03, 2013 | KitchenAid KEBS179B 27" Built-in Electric...
My double oven is flashing code F6 and E2
Error Code F6-E2 means that your oven temperature sensor has failed as well your electronic control board.
The oven temp sensor, electronic control board and the touchpad must be replaced.
Before you decide what to do, check the thermal fuse at the control panel first. If blown, replace it and the temp sensor. If you are lucky the control board may still be good.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 23, 2011 | KitchenAid Ovens
Model JRP15WOW1WW GE Oven beeping and showing code F-7. Help
Hi
F7 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | GE JKP15 Electric Single Oven
Error code f6eo
F6 - E0 Return line not connected If switch pulse return line is not connected, electronic control will display F6 within 60 seconds after power up. Replace control.
Apr 25, 2011 | KitchenAid Architect® KEMS308SSS Stainless...
Error code f6eo
Dec 26, 2010 | KitchenAid KEBC147 Electric Oven
I have a kitchen add KGSS907 it is showing an error message F6E0 lost communications how do I correct this
F6 E0 means the switch pulse return line to the electronic control is not connected
The usual way to correct this is to replace the electronic control (clock).
You might want to check for loose or burnt out wires on the clock unit before replacing tho'.
Dec 17, 2010 | KitchenAid Architect Series KEBC107KSS...
E2 F6 ??? What the? Oven came with house, no manual.
Your oven temperature sensor has failed(e-2) as well as your electronic control board(f-6). The oven temp sensor, electronic control board and the touchpad must be replaced . Approximate cost of parts is $500.00. Before you decide what to do, check the thermal fuse at the control panel first. If blown, replace it and the temp sensor. If you are lucky the control board may still be good.
Jun 12, 2009 | Whirlpool RBD305PD Electric Double Oven
Shuts off when preheating with F3 or F6 error
The F3 error on this model is an open thermostat circuit. The F6 is a control or loss of power. Make sure the unit is plugged into a good 120 Volt outlet. Test this outlet with a power drill or lamp, wiggle cord in receptacle, if no other test experience or equipment is avaliable. Check the thermostate in the oven for physical damage. There may be a loose connection in the oven. This would require a good technican to find.
InMrFixIt
Feb 20, 2009 | Kenmore 33169 Gas Single Oven
Ovens Logo
125 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
