Question about Toshiba Portege M100 Notebook
Giving message windows could not start because the following file is missing or corrupt :windowssystem gaoen.fon
I have an evo n610c and it started up with a message that says, "Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair thi
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
Feb 15, 2013 | HP Compaq Evo n610c Notebook
After booting up samsung NC10 error message saying windows could not start because following file missing/corrupt \windows\system\vgaoem.fon
OK, try, Boot Up in SAFE MODE, press F8 At Boot up, quickly, select, Boot to safe Mode desktop, with networking... simply copy vgaoem.fon file from xp disc or from net, paste file into windows system folder, done.
OR You could simply perform a system restore back to another time BEFORE you had a problem, again start up in Safe mode, F8. but this time when the choice is given to choose safe mode desktop or system restore, choose system restore, when a calendar like thing is displayed choose a time PRIOR to this problem happening, follow instructions and before you know it your PC will be back.
Oct 15, 2010 | Samsung Computers & Internet
Compaq Windows XP Home Edition Presario 700 Startup>Start Windows normally>Windows could not start because the following problem is missing or corrupt:WindowsSystem gaoem.fon I don't have a disk...
compaq has a restore directory on the drive
turn on computer boot in safe with command promp
type in restore it should boot
failing that insert original floppy and it will ask you to pick an option '
Jul 31, 2009 | Compaq Presario 700 470024-192 Notebook
Vgaoem.fon
Hello there:
your problem is due to a missing or corrupt file this file is a key file that windows needs to operate.
please try this
Root of the issue
You might come across this error message and this behavior of Windows operating system due to missing or damaged Vgaoem.fon file. This is a key file for Windows operating system, which is required for Windows to boot up.
How to recover inaccessible or lost partitions
Follow the underwritten steps to sort out the issue:
  • Configure your PC to start from CD/DVD
  • Insert XP bootable CD and restart the system
  • Boot the system from CD and press R to start system in Recovery Console
  • At command prompt, type map and press enter
  • Type underwritten line and hit enter: expand CD-ROM drive:\i386\vgaoem.fo_ drive: \windows\system here CD-ROM drive is the drive latter of your CD Drive.
  • Type exit and restart the system.
If your system works properly, then the problem is resolved. In the else case use Partition Recovery Software to recover lost hard drive partitions and data. These tools are particularly designed to effectively scan the affected hard drive and retrieve all of the lost, missing and inaccessible hard drive partitions. These applications are quite easy and safe to use. i hope that this helps
best regards mike
Jul 22, 2009 | Compaq Presario 5000 PC Desktop
For Windows won't start problem, I have met the same situation before. It was Windows Boot Genius to fix problem easily!
Jul 03, 2009 | Toshiba Satellite L25-S121 Notebook
Gateway 9500 windows wont start
these are essential windows files you will need to reinstall windows in repair mode
set bios to boot from cd you will during boot up be asked to press any key to boot from cd press any key when widows loads all its drivers etc windows will ask what you want to do press r for repair and follow instructions
during setup windows will reboot a few times when it does do NOT press any key
Jul 27, 2008 | Gateway SOLO 9500 (7002886) Keyboard
Boot up issues
run cmos bios and configured boot device..first boot cd rom drive..
then reinstall/repair your os...
Mar 24, 2008 | IBM ThinkPad T21 Notebook
BENQ Joybook 2100
u need it to repair does afreinds have it burn a copy of it on 16 x or less ok
Nov 30, 2007 | BenQ Joybook 5000 Notebook
Toshiba Portege M100 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
