SOURCE: Sharp aquos lcd screen goes blank
i was having these same problems with the screen going black, and i found that when i hit the back of my tv it would work sometimes. so, i improvised on some of the advice on this page and so far no problems. here is what i did (its very easy):
1. lay the tv on the floor and take off the back panel. (i think 12 screws)
2. on the right side of the tv (as you are looking at the back) you will notice a large metal covering that is held in place by 6 screws. unscrew these and remove the metal cover.
3. you will notice that the three screw holes on the left side of the board have some sort of metal or solder around them, in sort of a star pattern. when i looked closely i noticed that most of the metal (solder) was tarnished, or kind of blackened. (this must mean that the ground screws werent getting a good connection and this would explain why it would work sometimes when i hit it because it would vibrate the screws enough to get a good connection! )
so, take a pencil eraser and erase all the black or tarnish off the metal surrounding the screw holes. thats it! (to be safe i took some sandpaper and cleaned up the screw holes on the back of the metal covering, but i dont know if that was necessary)
at this point i followed another gentleman's advice to do a hard reset. this involved unplugging the 8 connections although i dont know if this was really necessary because i believe my problem was a ground issue. i did it just to be safe. his advice is on this site if you want to do this step.
4. i put everything back together and it worked! i performed a soft reset at this point which puts your tv back to factory settings. just go to menu>setup>reset>return to factory settings? yes
this will turn your tv off and back on. that's it. so far so good for me.
SOURCE: Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
SOURCE: my tv screen just went blank i still get sound but
its the motherboard. i got the same tv with cracked screen. i can sell you the motherboard for cheap or i will buy your lcd to fix mines. if interested email me at [email protected]
SOURCE: westinghouse 32 inch screen goes blank
Westinghouse LTV-32w1
replace capacitor c162 on power supply
power supply was a delta electric dps210ep-2c rev01
reheat any solder joints that don't look 100% as well .
such as c310 .
this is a known working fix . try before you buy a supply .
SOURCE: IHave a 32 inch flat screen Westinghouse TV that c...
Ur tv the LCD inverter board it dead.The LCD inverter is the board that help the LCD screen panel to get a backlight to produce a picture,the LCD inverter board is dead and it not working anymore that why u only get 8 sec.of the picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
