Question about Brother MFC-8460N Laser Printer
Brother MFC 8460N All in one
The machine will not recognize that paper is in the tray. Therefore it will not print.
It appears that the mechanisim that should lift the paper up against the sensor does not rotate the plastic gears to lift the paper. Therefore the visual gauge that shows the fullness of the tray stays a what looks like a full tray when the tray is not full. The metal plate does not rise up to force the paper up against the little plastic sensor hanging down from above.
  • 2 more comments
  • brotha Dec 14, 2007
    have same problem.
    any one know how to fix this problem?
  • syscoord May 26, 2008
    I'm having the same issue, but I'm also getting a snapping noise as it tries to load the paper tray into the up position.
  • hottubking Oct 12, 2008
    will not recognize paper loaded in tray - 2 identical printers, same problem with each.
  • TexasShooter Dec 30, 2008
    My MFC-8460N is giving me a paper empty error and offering only a snapping/popping noise as it fails to lift the metal lower tray and feed paper from the main tray. I have been told (by copier repair ppl, over the phone) that the rollers probably need to be replaced. Anyone else offer an alternative (read: cheaper) fix for this problem?
Remove your tray.
Push it from the back and make it sure it's tight against the paper.
Move the blue button to the "unlocked" position.
Should be good to go!
Posted on Jun 18, 2008
I found the problem was with MS Word. The tray has to be set to Tray 1 and not MP.
Posted on Mar 21, 2008
BROTHER MFC-8460N / After inserting paper tray the machine will not pick up paper. There is a clacking sound & an error message: no paper
Try this out.
1. Page Setup
Paper
(Paper source) - First page: Auto Select; Other pages: Auto Select
2. Print
Properties
Paper/Quality - Tray Selection (Paper source): Auto Select
Regards,
Shawn
Jan 31, 2011 | Brother MFC-8460N All-In-One Printer
Printer says there is no paper, therefore it won't print..........
Hi Shelly
This is unfortunately very common issue about MFC-8460N, There are few steps you can try, Set to factory default (Reset), move the roller manually so sensor will detect new position or locate the paper detector and bypass it. There are many users have been complaining regarding the issue that you have, Before try the troubleshooting that i have suggested please do call the hotline of Brotherif you have ongoing warranty. Some cases Brother accepts their fault on this known issues and provide solution (can be free of charge). As an experienced expert I suggest you to contact Brother (1-800-276-7746).
If you cannot find any resolution please post we will try our best to help you.
Good Luck
Jan 27, 2008 | Brother MFC-8460N All-In-One Printer
Paper is in the feed tray, but it continues to say NO Paper??? Brother MFC-8460N any suggestions?
Could be a tab or spring broken off of the feed tray, dirty feed roller can cause that error when paper doesn't feed. Paper guide too tight so that paper can't lift to the feed roller also a possibility. Sensor above paper stack out of position.. many possibilities.
Nov 06, 2009 | Brother MFC-8460N All-In-One Printer
We have a Brother MFC 8460N and it says "NO PAPER." However, there is paper and the spring in the tray is working fine.
Yes check that the shutter is ok and also ensure that the LED sensor is free of dirty(Use blower)
Jul 27, 2009 | Brother MFC-8460N All-In-One Printer
Mfc 8460n paper jam
Check to see if this happens when you use the drop down manual feed tray. If your printer works fine using the manual feed tray the problem is with your paper tray. Check to make sure it is set to letter size. I've found that sometimes the 'teeth' holding the paper stop on the paper tray wear out and when the printer goes to pick up paper, it pushes the paper stop out of position causing the printer to think it's using a different, much longer size paper thus preventing it from feeding all the way through. You'll probably need a new paper tray if this is the case.
Jan 06, 2009 | Brother MFC-8460N All-In-One Printer
Printing problems
If it is approx 3-4 smudges down the page. Replace the drum cartridge.
Oct 30, 2008 | Brother MFC-8460N Laser Printer
No Paper Message- when the tray if full
When removing the tray - turn off printer -
insert try with paper - turn on printer -
you should notice the blue paper meter moving. fixed
Oct 20, 2008 | Brother MFC-8460N All-In-One Printer
Document jam brother mfc 8460n
you cannot clear this unless there is still a presence of paper inside the machine.
or you can open and close your machine once you are cleared of any paper jammed, be sure not to leave and removed all residual paper in the paper path, the tiny sensor would recognize any sort of this and thus make your machine unoperable.
Jul 25, 2008 | Brother MFC-8460N All-In-One Printer
Brother MFC 8460N Paper Jam
paper jams alway in the same spot- just as it's about to exit the bottom tray
Feb 08, 2008 | Brother MFC-8460N All-In-One Printer
Brother MFC-8460N Laser Printer Logo
953 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
