Question about Gibson Thru-Wall/Window Air Conditioner
Air filter change
I want to change the filter but am not able to get the front off to do so. Is there a trick to this?
Margrit
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 80 Answers
I'm not sure what model you have but but you should not have to take the face off most newer units have a slot on the side you just push the filter out wash in sink or tube make sure it is completely dry before placing back in the unit
Posted on Jul 19, 2009
How to change air filter on 2006 Toyota Hiace SLWB diesel automatic?
Hi josephjohn,Here are instructions on How to Change Cabin Air Filter in a Toyota. It is recommended to replace this filter at every oil change.
Jul 29, 2014 | Filter Queen Defender Air Purifier
I have a bagless cyclonic vacuum but filter in cylinder is not spinning
The filter doesn't spin The air creates a vortex as it is drawn through to the motor and this action is what spins the dirt out of the air. It is the sudden change of direction that does the trick
Mar 24, 2013 | Vacuums
Isufician air flow what does it mean
Clogged air filter/air intake; also it can mean your radiator grill is very dirty (leaves/pine needles/dirt)
Change your air filter, use a spray gun on a garden hose to spray out your radiator/a/c coils, see if that does the trick.
Hope this helps.
Mar 18, 2010 | 1999 Isuzu Rodeo
Changing the cabin air filter on a Saturn L300
Read through to the end of this wiper motor replacement story. Your job will entail everything except the wiper motor.
I had the same problem in my LW200. As the other poster indicated a new wiper motor will do the trick. This is an easy fix. Remove the wiper arms, pry up the plastic center cap and remove the nuts holding the arms down then pull them off. A soft prying nudge from underneath will help as they are splined shafts. Raise the hood, put a large deep well socket on over the splined shafts and remove the 2 large nuts holding the trim panel on. Pull up and off the long rubber which runs along the front of the trim panel, watch there is a sharp edge underneath. Now you can gently pull off the trim panel, remembering to lift it over the splined shafts. Mechanism is right there, remove 3 screws and unplug wiring. Take wiper motor off the linkage, swap with a new one from advance auto, about 100 bucks, reinstall in reverse order. Note there is a stamping on the linkage telling you where the pivot arm should be for the rest or stopped position and if you ignore that your wipers will be out of whack. While you are in there you may want to change the cabin air filter as well as it will be right in front of you.
Oct 04, 2009 | 2006 Saturn L300
When I run the air cond there is a unpleasant odor the we smell. The unit has not been used for a 3 years. Any thing I can do to get rid of the odor. can I clean something ? Change filter ? Ron
Definately change the filters, but im sure there will be an odor from sitting around. Clean the evaporator coil , not with high pressure wash, dont wanna damage the fins, they sell cleaners at HVAC suppliers. That should do the trick
Aug 13, 2009 | Coleman Heating & Cooling
2008 Dodge Avenger SE
Hello
Here is from the chrysler service contract manual
for all dodge 2008
oil change
oil filter change
rotate tires
lubricate front drive shaft fitting (2500 or 3500 4X4 models only)
check spare tire for proper pressure and correct storage
lubricate outer tie rod ends (2500 or 3500 4X4 models only)
inspect engine air cleaner filter, replace as necessary
RD
Jan 13, 2009 | 2008 Dodge Avenger
92 camry fuel filter location
look under the air filter box, bolted to the framerail
Dec 27, 2008 | 1994 Toyota Camry
Gibson  Thru-Wall/Window Air Conditioner Logo
104 people viewed this question
Top Gibson Heating & Cooling Experts
john h
Are you a Gibson Heating and Cooling Expert? Answer questions, earn points and help others
