Question about Hobart HL600 Legacy Stand Mixer
The handle on my h600 that raises and lowers the bowl broke off. Where can I find a new one?
    Scholar:
  • 81 Answers
Stove Parts Supply, Ft. Worth Tx
Posted on Jul 25, 2009
How do i adjust the bowl height on an ksmc5os?
I'm not familiar with your model but on stand mixers with crank handle bowl lift there are 2 places for it to be. With bowl lift down there can be s screw straight in from the front on the pedestal just above the bowl lift sliding bracket, the full range of adjustment is half a turn, anti clockwise to raise, clockwise to lower. The other one is a small screw sticking down from under the gear case where the bracket that carries trhe bowl slides up and down. Clockwise to lower, anti clockwise to raise.
Aug 19, 2014 | KitchenAid KSMC50S Commercial Stand Mixer
Missing the bowl raising handle
Check your manual that came with it. There's usually a customer service number. Things like that usually must be ordered dirctly from the manufacturer.
Jan 01, 2013 | Uniworld Commercial Kitchen Mixer 20 Quart
Cant raise and lower mixer bowl worm gear and nut is striped how
How could we possibly know what you are capable of doing?
Apr 15, 2010 | Hobart H600 Stand Mixer
Hobart HZ (h600?) Raising handle is acting up
You will need to confirm the model number. An H600 or L800 have a wheel to manually turn to raise and lower the bowl. The M802 and V1401 hav a belt driven bowl lift clutch, operated by a lever. When you push the lever up or down, you are engaging a small transmission between the motor and main housing. You would need to remove the top cover and see what's happenning. It may be there is something other than the proper spiral pin joining the lift lever to the clutch input shaft, giving alot of backlash and insufficient selector movement.
Aug 18, 2009 | Hobart H600 Stand Mixer
call hobart, give them the info off the name plate and they will mail you one.
Jul 19, 2009 | Hobart Food Mixers
Hobart Mixer bowl won't go up
If the worm screw is turning but not lifting the bowl, the bowl lift nut is stripped.
H600 part number is 24198.
To change it, you need to undo the screws down the right side yoke slide to release the yoke. You will need to lift the yoke to reach some of them. If you have some wood place it under the yoke and over the legs to protect the paint. On top of the yoke are two blots holding the keeper plate over the nut. One is the stop screw for bowl height. Don't loose this setting. remove the slide, edge the yoke forward a bit to free the worm. Run the old nut down the worm and off the bottom. When you run the new nut on, all the excess grease and metal shavings will start to build up. Clean as you go, or better still, brush with solvent or similar to clean the worm threads . relubricate, run the nut up above the yoke, reload the yoke and attach keeper plate, reload slide.
To adjust slide, snug screw near bottom keeping slide close to yoke, run yoke to top and tighten top screw just enough to hold slide in place, lower yoke to bottom, gently tap top of slide in a 1/16" and tighten top screw. Run yoke to top of slide. It should start to bind slightly in the last 2 inches of travel, which will stop the bowl from dropping in use. Tighten remaining screws.
May 13, 2009 | Hobart H600 Stand Mixer
Plastic piece that raises and lowers the bowl
planetary is the mixining action which was started by kenwood on there mixers in the 50s
Dec 14, 2008 | KitchenAid KP2671 Professional 6 Series...
Need to Raise the stop height of the bowl on the H600
I should have know this was a scam to sell something.
Thanks, but no thanks.....
Dec 09, 2008 | Hobart HL600 Legacy Stand Mixer
Hobart H600 bowl wheel slips
Some of the older H600s do not have a bowl lift lock. Look to page 18, items 57-72.
http://www.hobartlink.com/Extranet/ExtranetManualsAndCatalogs.nsf/6E1A88214EC64B59852568E1006A99F9/$File/F18797%20Rev%20B_lk.pdf
Take off the cover and see if the assembly is there. If not, get a bungee cord for the handle. If it is, when you start the mixer the solenoid should fire and lock the gears in place.
If the assembly is there and not working, check the it is not binding. If it is, free the assembly up and check the solenoid. If it was frozen it usually causes the solenoid to overheat and burn out. Good luck - Mike
May 08, 2008 | Food Mixers
H-600 Turn Handle slips, bowl does not go back down
Does the handle seem to move easier?there is a shear pin on the handle and if it breaks the bowl wont move.Another thing to check is remove the silver plateon the front of the mixer there are 2 possibly 4 screws,when you remove this plate you will see a long screw about 3 feet long.turn the handle if the screw doesnt turn that pin may be broken.let me know.
Mar 18, 2008 | Hobart H600 Stand Mixer
Hobart HL600 Legacy Stand Mixer Logo
125 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
