SOURCE: Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
SOURCE: Need online repair manual for evinrude 50hp outboard
how can I adjust the shifting linkage on my 50hp evinrude. I have the cable adjusted all the way out but it will not go into reverse
SOURCE: gth2548 25hp 48" - bolt
Hi hoofprintsfa,
Welcome to fixya!
Here is the website for your manual: www.mymowerparts.com/pdf/Poulan_AYP_1/logt25h48a_e.pdf
Copy and paste this address into your web browser and the manual will be ready to download for you.
Here is a website where you can get parts for your tractor. It includes a parts diagram: http://www.partstree.com/parts/?lc=&mn=Gth2548
Hope this helps. If it does, I'd appreciate your vote. Keeps me working here.....
Thanks,
Handie Andie
