SOURCE: low amp output
Make sure the BOSS isn't in "Protected" mode (Red led lit) and connect the speakers properly (check the connections if they are in "bridged" mode).
Also, make sure you set the cross-over, bass boost setting, bass volume control and the bridge mode according to the speakers you are connecting. Check the input level too.
The BOSS amplifiers are of very poor quality and it can be easily broken. Maybe yours is broken.
SOURCE: ok i have a hitron 2000 watt monoblock D class amp
theres a switch on you're hitron amplifier that'll say bridged or unbridged you wanna flip that switch while the amp and speakers are on and everything is hooked up but make sure you're bass is on minimum so you dont pop your subs once u flip that switch everything will work amazingly, the switch is between where your speaker wire is hooked up and where you have your power wire, you can't miss it.
