Question about Evenflo Jenny Lind Crib
Got everything put together but don't know how to assemble the drop down side. New Generation #70011
  • 164 Answers
Screw the 4 plastic things to the legs even and lined up with the other side and the 2 on the bottom should let the side slide onto it and the attach the other 2 up top and slide the side up onto it.
Posted on Jul 20, 2009
Is generation two crib model 10-2109 one that was recalled
if I remember correctly the recall affects all cribs that have a side drop. here is the recall link if your crib can slide down on the side than yes it's being recall.
https://www.cpsc.gov/Recalls/2010/generation-2-worldwide-and-childesigns-drop-side-crib-brands-recalled-three-infant
Feb 24, 2018 | Generation Baby Gear
My kitchenaid k5ss will not turn on My mixer was running and stopped. I replaced the gears but when taking apart I found that the board on the very end was crcked an the bottom was broken. I replaced both...
Heheheheheh, not laffing at you but with you, You have just assembled stuff in the wrong place and you have to now adjust the speed control board to get the mixer to start up. Go to the KA site click on support click the drop down menu and click on get manuals then on left side of page click first and choose servicer then drop down and list your model number just as it is listed on the sticker under neath the mixer, click or hit enter and you will be taken to a new page with PDF forms the top section is the owners manual and the second section will be the parts list go to the matching model number and click on it scroll down to your manual and click on it, it will expand in a new window, scroll down and you will see the parts for the electrical area of the mixer, it is easy to figure out and you will quickly see the manner in which you need to assemble everything properly, once you have everything put back correctly you will need to adjust the 3 screws on the speed control plate. start with the two top screws chrome on the top of the black and copper plate, turn counter clockwise until the mixer starts, You can find a few good tutorials about this adjustment on utube that you can use as a guide. Hope this helps please let us know if it did.
Mar 21, 2013 | KitchenAid K5SS Heavy Duty Commercial...
My shaving head came apart and I can not re assemble it, kindly give me instructions
Wife cleaned bathroom shelf dropping the Arcitec. One of 3 heads was not aligned properly, when I tried to re-seat it, this head came apart. To put it back together takes some finesse and patience. Take a coil of stamps, or some other small opening to rest the outer plastic shell head, then insert the metal screen which has notches (2 small, 1 large) and fit it in the plastic shell head. Next put the metal blade assembly on the screen. Next align this on the metal (thin) pivot. When the outer plastic head, and the metal pivot are aligned (small peg holes), you can place the thin inner plastic piece on and gently press your sub assembly and the backing plastic together, It will snap together and hold. Don't FORCE it, the holes must be aligned on the outer plastic, the metal pivot frame, with blades resting on the screen. It does snap together. Work with fairly bright light to see what you are doing. If this fails, invest in a new head assembly for about 15% of the cost of the whole razor.
Jun 10, 2011 | Norelco Arcitec Electric Shaver -...
I have model # 74-3151 and I need to take it down to give to my sister, my son has out grown it and I don't know how to.
GENERATION 2 IS OUT OF BUSINESS AND YOUR CRIB IS RECALLED.
Take it to Walmart for a full refund of the original retail price and buy a new one!
No receipt required.
http://www.cpsc.gov/cpscpub/prerel/prhtml10/10134.html
"However, all Generation 2 Worldwide and "ChildESIGNS" drop side cribs are included in this recall, including those with other model numbers.
Mar 01, 2011 | Generation 2 Worldwide Geneva Crib
Need hydro drive wheel right side for craftsman zt7000
its a zt7000 craftsman homeowners sit down 0 turn mower.mower is made by simplicity 18 hrs koler. since i last posted i had a freind who works on hydro motors for a living break it down clean it and look for visual damage. there was none so it was put back to gether. new gasketts and lubed. after assembly neither side work at all now and makes a grinding noise when levers are put in reverse. left side worked before right side was taken out, left side was never touched. resovours were filled and everything was put back together correctly im positive. im at a loss with this.
Nov 01, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Put front axle in,now i have a bad vibration
What was the original problem and, did you change entire diff/axle assembly or only one drive axle? (which side?) Before knowing any of this, I suggest you re-check your work to make sure everything is secure and that nothing has gone together crooked.
Jun 27, 2009 | 2000 Jeep Cherokee
Crib assembly
i have a crib with the same model number, except it's not cosco..at least i don't think it is. it's dorel. anyway, i have the same crib i believe, and if you say all the parts and hardware is there, maybe you forgot to put on the stoppers at the bottom of the sliding rail. that's the only thing i can think of. hope it helps...if not..try see if you can contact dorel.
Nov 28, 2007 | Baby Gear
Evenflo Jenny Lind Crib Logo
248 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Vic Fkiaras
Level 1 Expert
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
