Question about Motorola Mobility i880 Cellular Phone
Possesed Phone After the phone is on it starts doing all different things. It will go on the internet, it will say no voice tags found, it will play music, it will start ringing loud, it will go to speaker phone. Its like all these different buttons are being pushed and I cannot control it. The keypad wont even work when its doing this. Is there a way to fix it?
    New Friend:
  • 133 Answers
Re: Possesed Phone
Sounds like you may have liquid damage in the phone ..only way to tell for sure is to open it and look at the indicators..It is a tricky process and should not be done by some one who has never opened a i880 . I recommend you go to a service center..where are you located so I can tell you the nearest one..
Posted on Dec 05, 2007
0 characters
3 Points
How to activate voice dial phone feature
Touchscreen phones simplify the wireless world, especially when combined with voice activation. Although making calls using voice commands was an option before touchscreens became available, the method used to set up this feature is different than it is for non-touchscreen units. It can take time to master the set of procedures that will get the feature working.
Step 1
Create a voice tag. Touch "Contacts" on the today screen. This opens the list of contacts on your phone. From here, do one of three things: you can hold your finger on the desired contact and then tap the "Add Voice Tag," you can select the desired contact, tap on "Menu" and then "Add Voice Tag," or you can tap the desired contact to open their personal screen and then hit "Menu" followed by "Add Voice Tag."
Step 2
Record the voice tag on your phone. Touch the phone number to which you wish to add a voice tag then touch the "Record" button. Record your voice tag for that contact. An icon will be displayed to the right of the number when the voice tag is complete. You can listen to your voice tag by touching the "Play" button on the screen or you can delete it to record a new one.
Step 3
Make a voice tag for a program. Tap the "Start" button on the phone. Go to "Settings" and then the "Personal" tab followed by "Voice Speed Dial." Choose the program for the voice tag and record the voice tag in the same manner as you did for the contact. To open the program with the voice tag, tap "Start," "Programs" and then "Voice Speed Dial."
Step 4
Launch a program or make a call. Make a call by tapping "Start" followed by "Programs" and then "Voice Speed Dial." You will hear a beep. Say the voice tag you recorded for the person you wish to call. You can open a program via the same procedure (by speaking the voice tag created for the program).
Step 5
Check the voice tags you created. Tap on "Start," "Settings," "Personal" tab and then "Voice Speed Dial." A voice tag tab appears and displays a list of your voice tags.
Jun 20, 2016 | Cell Phones
I am having problem on finding and setting voice tag for contacts.
Feb 05, 2011 | Nokia 6720 Classic Cell Phone
My clutch wont play media files i send it to thru bluetooth why?
The file your trying to transfer is not supported by the clutch. Here are the files that are only supported by it.
15fps 128 x 96
15fps 128 x 96
15fps 128 x 96
Oct 09, 2009 | Motorola Mobility Clutch i465 Cell Phone
My phone says no voice tags found ...what does this mean ?
please save voice tags for contacts so they can be found
Jul 26, 2009 | Motorola Mobility i880 Cellular Phone
Motokrzr k1m adding voice commands for voice dialing
You should be able to add a voice tag while editing the contact. You may also be able to simply activate voice dialing and press the voice dial button and say the name of the person and it will automatically dial for you. Try doing that.
Dec 18, 2008 | Motorola Mobility KRZR K1m Cellular Phone
HOW DO I RECORD A contact voice tag lg vu (cu920)
You do not have to record voice tags for your contacts. Go to Tools, click on Voice Command then Settings and finally Train. Follow the prompts and once complete, your phone will them be able to recognize your commands. when you hit the call button on your bluetooth headset, the phone will say "Say a command". at that point you can tell it to call any contact in your list or tell the phone to call a number (i.e. call 601 555 0123). The phone will ask for conformation and then make the call. The phone will also respond to request to check missed calls, check voice mail and tell you the time and date. Hope this helps.
Dec 12, 2008 | LG Vu CU920 Cellular Phone
Voice tag andrei.your problem is very easy to solve...... try to change the microphone...^^
Jun 01, 2008 | Nokia N95 Cellular Phone
Voice tags
choose the contact you want then seek for add voice tag.
May 13, 2008 | LG Vu CU920 Cellular Phone
Saanyo Spc 3200,When using the voice tag, It works one day and drop them the next day
Does not depend on the phone, is the phone company that provides voice message service.
Apr 02, 2008 | Cell Phones
Nokia N95 Voice tags
i need to say u should save the voice tags in a silent place with keepin the phone at a smalll distance from mouth . say the words cleraly as u are u can repeat the word in the same clarity
Dec 04, 2007 | Nokia N95 Cellular Phone
Motorola Mobility i880 Cellular Phone Logo
23 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
