Question about Verbatim VER95327 USB Hard Drive
My external hard drive wil not work
My external hardrive powers up and i can feel it running, windows knows it's there but it will not show up in my computer. i cannot access this drive at all. is there a fix for that?
  • 696 Answers
Hi there are several fixes for this issues depending on the cause.
As you've identified it's spinning up we can likely rule out power problems. When you state windows knows it's there I assume you're either making reference to seeing the installing device notification or see the drive in device manager. If I'm correct, then your next step is the see if the drive itself shows up in Disk Management, which is in the same MMC console as the Device manager.(For reference: right click My Computer and Click manage to access the MMC).
If the drive shows up in Disk Managment, then the drive is likely working and the issue is a logical issue with the partition(s) or drive letters on it. If this is the case there are some good inexpensive ways to retrieve the data so you can reformat the drive and get it up and running again.
If the drive doesn't show up in disk management, then it is the enclosure circuitry not the drive windows is acknowledging and you have either a failed enclosure or drive.
If it is a logical issue comment back telling me and I will give you some options for resolving that issue. If it is a hardware issue, take the enclosure to your local PC shop and have the techs there move the Hard drive into a new enclosure and test it. If this works, buy the enclosure and you're on your way. If this fails let me know the steps you've taken and your location, I can refer you to a pro in your region who can attempt a data recovery on the dead drive.
Hope this helps FixYa,
Chris
Posted on Jul 19, 2009
Hardrive only flashes
Nothing Happens When Drive Is Plugged In b> Remove the USB or FireWire cable from the back of the hard drive and try using a different one. If the hard drive requires external power, try a different power cable and power outlet. Visit the hard drive manufacturer's website. All prominent hard drive manufacturers have utilities that can freely be downloaded, which will check the hard drive for errors and diagnose problems. Sometimes, these utilities can repair problems that Windows Disk Management cannot. Call the manufacturer to obtain a replacement hard drive if the utility reports errors or does not see the drive at all. Hope this helps.
Dec 28, 2012 | Samsung S2 - 1TB USB 2.0 Portable...
I have an external simpledrive hard drive, my computer won't detect my hard drive. i know it works, the light is still on, but the little popup window won't show up and it won't show in "my...
Try another usb port. If your using a desktop, try the usb ports at the back of the tower. Also use a shorter usb cable. Long usb cable has the possibility that a power lose will occur. Shorter usb cables has more direct power output going to the external hardrive. Also check your usb drivers in your device manager if it has errors. Right click on My Computer icon on the desktop, then choose Properties, then go to the Device Manager tab then click on the Manage Devices button, there you can see all your hardwares if they are working fine.
Jan 13, 2011 | SimpleTech SimpleDrive 160 GB External USB...
Windows xp will not restart with usb plugged in. I am running windows xp sp2 with a Hitachi 500g external hardrive that is designed to turn on and off with the computer. The same hard drive works fine on a...
Sir, your PC might have been checking for external devices which plugged in to boot from. Thats wrong. So get into the bios of your computer while startup and change the 1st boot device to your computer's hard disk. And its a bad idea, starting your computer with a usb device plugged in.
Jun 29, 2010 | Hitachi 500GB External USB 2.0 Hard Drive
External Harddrive doesnt show up in harddrive management.
it sounds like a hardrive issue. You can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Aug 24, 2009 | IBM TravelStar 48GH 48 GB Hard Drive
Verbatim external hardrive not showing up on computer?
A Hard disk making noise, does not sound too good. if it was waorking before on both PC's & not having issues then it has to be with the unit. try on a nother computer. if its the same thing i suggest you look for that warranty card of yours.
Jun 09, 2009 | Verbatim 160GB USB FireLite: The "drive...
External hard drive doesn't respond
Shut your computer down. Disconnect you external hardrive. Power up your computer again. Power up the Verbatim and then connect to a USB port. You should hear a very quiet 'ping'.
Go to My Computer, and the Verbatim should be showing as one of your drives (probably Drive D). You should be able to open it from there.
Make sure that you have a Desk Top Icon for opening the hardrive, it makes it so much easier. Hope this helps
Jan 25, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
Need to dump my data from my mac to my maxtor external hardrive
you need to backup your system using windows back utility on your computer and save the files to your external hard drive.
Good Luck
Jan 19, 2009 | Maxtor Hard Drive
Seagate external hardrive
Here is the link to the Seagate's utility tools: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=Downloads&vgnextoid=51e092db8a13d010VgnVCM100000dd04090aRCRD The links that you are looking for are DiscWizard and SeaTools. And if you have just lost it, here is a recovery program that you can use: http://www.download.com/VirtualLab/3000-2248_4-10642058.html
Mar 20, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Verbatim VER95327 USB Hard Drive Logo
167 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
