Coffee and Espresso Makers
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
Sapper alessi kettle
By southcoast on Nov 19, 2007
The kettle has two pitch pipes (the whistle) which scale up and need replacing from time to time. How do you remove the old pipes and instal the new ones? I have bought the replacement pipes from Alessi, but no instructions.
Same Problem
Feb 27, 2008
-   Didn't knwo you could get replacements for the whistle ... good news ... but wouldn't a scale remover fix the problem?-   Guest
Solution #1
posted on Aug 01, 2009
Not Rated)
SailsElan
Rank: Apprentice
Rating: 0%, 0 votes
I bought new pitch pipes for my kettle and they came with directions. The directions from Alessi say to push the old ones out from underneath (part of the whistle that rests inside the kettle when it is closed) with a flat head screw driver. When installing the new ones, they say to only use your finger to push them in from the top, using only the eraser end of a pencil if you need to push with something. Mine were very loose, however. Also, the side with M1 or S1 etched into the brass part of the whistle should go lettered-end down into the brass tubes.
Was this helpful?
Yes
No
Solution #2
posted on Aug 31, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
You need to find something strong and the right diameter to fit through the hole in the back, to push out the old pitch pipes. I used a twist drill - it doesn't matter if it gets trashed doing it - it does not work anyway!
Push the new ones in gently, they should go in easily, if they are a bit tight make sure the hole is clean. Clean it out with some wet and dry sandpaper.
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
I'm having trouble descaling my machine, the booklet says to remove the portafilter (I assume... (More)
Answer
my odea giro is pumping well after the 3 expresso. The first few cups have the pump going, then... (More)
Answer
Is there a water filter in the B40? If so were is it in unit? Also I am looking for a parts book
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coffee and Espresso Makers:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
