Question about Denon DVD-2910 DVD Player
Denon DVD-2910/955 player stopped working
One of the kids accidently sat on the remote and pressed something and now, although the power to the unit is on, the player won't work. All I get is a blank screen with a few symbols in the lower left corner. Is there a default reset ot somehting I can try? Here is what I see in the lower left:
Auto
INPUT DVD/VDP
MODE Stereo
SOURCE: Denon 2910 CD player malfunctions
By this time I figure most peoples warranties are expired. So give this a try:
1 Open the case.
2 Turn the unit on and load a disk.
3 On top of the disk transport, you will see a black disk trying to spin as it reads the disk. You might notice that it is a bit quite as the display goes to 00H00M00S. It should be fast and a bit noisy.
4 Try loading a disk again, except this time, try to help that little black disk spin. It might take a couple of attempts, but I was able to get my 2910 working again.
The last year I've had to do this 2-3 times. But it works. From what little I have read, it may just be an issue with lubricating the right part with the right oil. I've narrowed my choices to PTFE 3n1 oil, Lithium oil, or silicone oil.
now I just need to find the right places to oil.
There should be quite a bit of noise and speed
Posted on Sep 11, 2008
Benimur
  • 6966 Answers
SOURCE: Unlock Deno 2910
Initially, pls try:
  • Verify that the tray is empty/no disc in the player;
  • Shut down/off with the front panel On/Off button and not the standby;
  • Press and hold the Open/Close, Play and Skip Reverse (I<<) buttons;
  • Maintain pressing on the above buttons and Power-ON the player with the On/Off button, (again while still holding the above buttons till the "Denon 2910" disappears from the display);
  • pls wait till LOADING completes and the front panel would display 0:00:00;
  • Using the remote control, enter 7, 3, 1, 9, 4, 6, 2, & 8;
  • The Denon 2910 will go into standby mode. Soon as it is on standby, pls press the Standby button on the front panel;
  • Pls verify region free update by pressing the Stop and Skip Forward (>>I) buttons on the front panel. The display would show “Region_Ax” The x would be the former region number that the Denon 2910 is locked into;
  • Should it not work ouot as expected, pls redo all the above steps.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 10, 2008
SOURCE: How to reset my Denon DN-V210 DVD Player to factory default?
Hi Jason,
I have just bought this unit and have been using the menu recently. The only ways i can see to do it would be to either, (as you say) plug it into a HDTV, or navigate the menu blind and hope for the best.
If you press SETUP on your remote once to get to the menu setup screen and then push the RIGHT navigation button 3 times this should take you to the system setup screen. Then push the DOWN navigation button 4 times and then push ENTER. At this point it asks you for a 4 digit password to reset the unit which is a factory preset, 5555, so type that in. This should then reset the DVD player to factory settings.
Hope it helps,
Nick
Posted on Nov 19, 2008
walesarumi
  • 6993 Answers
SOURCE: Denon Dvd-2910 only displays black and white on
this is not a serious problem. It just has to do with visual compatibility.
Change the DVD display to Pal or NTSC and set that of the TV to Auto or pal.
You might find the PAL/NTSC on the DVD remote, or on the button of the DVD. If it is not there, then Check display settings of the DVD.
As for the TV, Change to Auto or Pal from display settings.
Take care.
Posted on Jan 01, 2010
SOURCE: DVD player won't read disc anymore
i had the same problem.
is the player done? or is there a fix?
Posted on Jun 27, 2010
I have a Denon AVR 1802 and everything seems to be working properly, but I an mot getting any sound from the unit. When I perform a test tone, I get sound from all the speakers, but I can not get sound...
You could try a total reset of the system. To do so, Press Power while simultaneously pressing Speaker A and Speaker B. When the display flashes at about 1 sec intervals, release all buttons. Then select a desired source as normal and see if it plays as expected.
Nov 06, 2010 | Denon AVR-1802 Receiver
My kids turned my tv off sat to watch a dvd how
If you have the original remote press the input button at the top right. If that doesn't work or you don't have the original remote try channel - or +
Here is a link to the owners manual http://support.jvc.com/consumer/product.jsp?modelId=MODL027812&pathId=78&page=2&archive=true
May 07, 2010 | Televison & Video
Need code to Dish Network Remote Control for Sharp DVD Player DV-S1U
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Apr 20, 2010 | Sharp DV-S1U DVD Player
Mar 02, 2010 | Denon DVD-1740 DVD Player
Lost remote to portable dvd player
Any universal remote will work. Just look on the back of it to make sure it supports your brand. That's the key. Just follow the directions for manual input. It will work something like this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 24, 2009 | RCA DIRECTV Satellite Remote Control
Unlock Deno 2910
Initially, pls try:
Nov 10, 2008 | Denon DVD-2910 DVD Player
Denon dvd 2910 locked up
You will have 2 choices here, replace it or have it repaied
Jul 06, 2017 | Denon DVD-2910 DVD Player
When i try to open my disk tray it says locked
I had same problem with JVC player. Found out from manual that there is child lock- activated by pressing stop + eject when unit in stand-by mode. (which I must have done accidentally) Unlocked by repeating action - in stand by mode.
May 24, 2008 | Televison & Video
Avr 1804 denon 7.1 reciver
Did you check the Audio-Video slider button in the middle of the remote? It needs to be on Audio, else the remote sends video channel number signals when you press the numbers.
Dec 26, 2007 | Denon AVR-1804 Receiver
Turn off progressive scan mode
If you set progressive scant On by accident,you must reset the unit. Remove any disc from the unit and close the disc tray. See that "disc" is displayed on the display window. Now press STOP and hold it for more than 5 seconds before releasing it. The video output will be restored to the standard setting and picture will once again be visible on a conventional analog TV or monitor.
Sep 05, 2006 | Zenith XBV443 DVD Player/VCR
Denon DVD-2910 DVD Player Logo
104 people viewed this question
Top Denon Televison & Video Experts
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
