Question about Kenmore Elite Oasis ST 6806 Electric Dryer
I DROPPED A METAL HOOK IN THE DRYER LINT AREA, CAN I REMOVE IT MYSELF?
    President:
  • 1,273 Answers
Yes you can. If you can see it, try using a magnet taped to a stick, or adhesive tape rolled sticky side out on a stick. If you cannot see it, get a dryer brush (~$10 @ Lowe's/similar). Bend the brush to approximate the curvature ofyour lint caxity and sweep it back towards you. Once you can see it, try the tape or magnet trick to remove it. Don't go any further into the dryer without unplugging the dryer.
Best regards, and happy fishing!
--W/D--
Posted on Jul 19, 2009
Dropped something down the lint trap
If it's a metal utensil that responds to magnetism, try a magnet on a string, or one of those telescoping magnetic picker-upper tools to get it out.
Jan 22, 2014 | Amana NDE2330AY Electric Dryer
Lint screen won't go down all teh way.
take the metal duct out that the lint filter slides down into,stick the metal strip through the hole in the side of the duct so that when it's in the bottom part of strip is flush up against the back side wall of duct and it should have like a half inch or so sticking out of the hole,but before you stick it in clean out the duct and with a thin long screw driver open the plastic cover that the filter slides through and poke out any lint in the slots that the filter slides in.so unplug the dryer,remove the bottom panel of dryer,remove the lint filter and screws that hold the lint filter duct in place they are 1/4 inch head screws,clean out the duct and the side slots up above the duct in the plastic area then slide the metal strip into the hole so that the bottom part that you first put into the hole fits flush up against the back inside wall of duct and the top of strip will be flush to the outside wall of duct and like around 1/2 inch or so still showing.hope this helps
Jun 02, 2013 | Kenmore Elite He5T Dryer Heating Element...
Model Whirlpool le8650. My dryer stopped working. I noticed the brass clip in the upper right corner just above the door had broke off. I locaated 2 screws that were holding the part that was broken. I...
Unplug the dryer.
Remove the lint filter.
Remove the 2 screws at the lint filter slot.
Place a flat blade screwdriver under the front edge of the top and pry it up. Remove the 2 screws holding the front panel to the cabinet on the right and left sides just inside the cabinet.
Replace the door switch assembly and reverse the above order to re-assemble the dryer.
Sep 19, 2010 | Whirlpool Dryers
Brand new dryer. **** went down lint filter area
You may have to remove the front panel to enter the air passages and blower fan. Try feeding a vacuum cleaner hose (remove the metal hose end) into the area behind the filter to see if can pick up whatever dropped into it. Hope this helps!
Apr 12, 2010 | LG DLE2050 Dryer
Dropped pen into lint trap. Now Dryer makes a screeching noise.
The pen has fallen into the blower housing and is hitting the fan blades.
Unplug the dryer!! Remove the two screws at the top of the lint trap. Remove the rear panel. Remove the four screws at the bottom that attach the lint filter housing to the blower housing. Then, remove the pen from the blower housing.
Apr 06, 2010 | Kenmore Dryers
How do I clean the lint out of the Kenmore Eite He3 past the lint screen?
Remove lint screen. Remove bottom front kick panel (usually three to four screws on very bottom front), There is a metal lint filter air duct assembly that has three to four screws holding it on. Usually one on each upper side of the duct, and one that has a bent metal bracket holding the bottom to the blower housing. This metal duct is dead center in the dryer under the door and ducts over to the bottom left. Remove the screws and pull the duct down and out. You can now clean this assembly. Needless to say, always unglug the dryer or turn it off at the circuit breaker before doing this job. I recommend that you do this at least once a year on the dryer, and clean out the washer lint and coin catcher at least once a year. Good Luck, Appliance Specialists.
Dec 20, 2009 | Kenmore Elite HE4 Electric Dryer
The dryer is heating but clothes aren't drying. There isn't much lint on the filter and the inside door and lint area is damp with wet lint spread around that area. It is a MDE5500AY model. Serial...
This just happened to us a couple of weeks ago, and we called a repair man. I might be able to save you $45 for a service call. In our dryer, the lint can fall out of the lint screen and clog up in the back of the dryer. Remove the back of the dryer (you might have to unscrew the lint screen too) and the ductwork inside the back (it's quite easy, I've now done it since my daughter dropped my sunglasses down the lint screen hole) just keep an eye on your screws. Remove the trapped lint, and vaccum out the hose, making sure there's no kinks in the hose as it runs to your house exhaust. Put the dryer back together and see if it works. If not, you've got a fan problem and will need a repairman. But apparently this is the most common dryer problem and will take about 20 minutes of your time to straighten out.
Nov 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dropped bleach pen into lint trap. How do I get it out?
its not too hard to get out.
you will need a #2 phillips screwdriver and or a 1/4" socket driver
remove lint trap
remove 2 screws at lint trap
unplug unilt
open the top (2 clips between lid and front panel in the crack, push them with a butter knife or putty knife to release top) opens like a hood
pull out dryer and pull off rear panel
on the left hand side there is a metal duct like thing lol
that leads to the lint trap at the top.
there should be 4 screws at the bottom where it gets round.
remove them, and wiggle the duct open. your pen should be there..
May 25, 2009 | Kenmore 62602 Electric Dryer
HOW TO PUT DRYER RACK INTO WHIRLPOOL CABRIO #WGD6600VWO
If it is a dryer with the lint screen on top place the two ends of the metal loop into the two holes closest to the plastic clips on the bottom of the rack. The clip the metal bar down into the clips and the multi-bent part of the metal ring are now atteched to the bottom of the plastic rack. Turn it over and place the metal ring in to the back of the dryer and the front lip of th plastic rack then hangs loosly over the lip of the bottom of the opening of the dryer. It will all tighten up when you close the door. Hope this helps
Apr 18, 2009 | Whirlpool Cabrio WTW6600SBK
Dropped something in dryer trap
You can gain access or remove the lint trap by popping the top of the dryer up, then remove the front panel.
Apr 18, 2009 | Dryers
Kenmore Elite Oasis ST 6806 Electric Dryer Logo
48 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
