Question about Garden
How do you get the trimmer head off of a TroyBilt TB475SS
4 Suggested Answers
SOURCE: Troybilt 4 cycle trimmer (TB475ss) won't start.
Take the plastic cover off that covers the muffler and cylinder head. I've had 2 cylinder heads crack. The trimmer still ran but had little to no power and would not throttle up. First head cracked at the head bolts. The second one cracked above the bolts. The side that has the carb and fuel tank is harder to see and you must remove the carb and fuel tank to check. Also I've read online that this trimmer has a problem with the fuel line cracking at the bulb and in the tank.
Posted on Oct 29, 2009
  • 5 Answers
SOURCE: Pull starter
easiest thing is to take it off machine-that is the housing holding the string/handle-usually 4 screws-very easy(they may be allen wrench screws)and take it to a local lawn place and ask them if they rebuild them or if its cheaper to maybe just buy/order the entire thing if they have it/can order.It would probably cost 20.00 tops for the new housing with string and handle ready to go.Hope this helps
Posted on Jun 29, 2010
rycgl
  • 1545 Answers
SOURCE: The tb475ss trimmer will not
It is difficult to diagnose a no start problem without the machine being on hand. You need to check for blue spark, fresh oil and fuel and a clean air filter. You also need to verify that the engine isn't worn out and that it has compression. To try and get it to start, remove the air filter and squirt some aerosol type carburetor/choke cleaner into the opening to the carburetor. If it runs a few seconds, that is good and eliminates some of the causes. It may just need a good carburetor cleaning. Post back with results.
Posted on Oct 16, 2010
I want to remove the trimmer head from my Troy Bilt straight shaft trimmer model no. TB635 EC. Can you help?
Try the manual here
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/trimmers/TB635_769-10058.pdf
Oct 01, 2017 | Troy Garden
Model TB425CS WHAT IS SPARK PLUG GAP
Al, .025" is the plug gap for your trimmer,page 20 in your manual. There may be a recall on your model to do with safety.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/tb475ss.html
Troy Bilt Model TB425CS Parts
Troy Bilt String Trimmer Sold at Lowe Recalled for Laceration Hazard
May 15, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Fixing straight shaft attachment on Troy-Bilt string trimmer
Here is a link to sears parts direct. You can see prices for all parts and make a decision from that.
TROYBILT Trimmer Boom and trimmer Parts Model TB75SS
Aug 16, 2014 | Troy-Bilt Tb75ss
Tbp6040'trimmer head disassemble
www.troybilt.com/equipment/troybilt/ownercenter
Oct 22, 2013 | Troy-Bilt 25cc 4-Cycle Straight-Shaft Gas...
I have a Troy Bilt 4 cycle trimmer, TB475SS. The small fuel line in the gas tank has come off. I is about 6" long with a filter at the end. The trimmer can not **** any gas. How can I reattach it...
i would suggest to change all you fuel lines. troybilt uses specific fuel lines that they sell. you cant use your regular tygon fuel lines.
Sep 23, 2011 | Troy Garden
I need troy-bilt trimmer TB90BC engine schematic or manual for model# 41BDT90C711
you should be able to find the manual for the trimmer from their web site... you need both the model number and serial number to get the manual. i'll put the address you need below
Canada
http://www.troybilt.ca/troybilt/troybilt_manual_search.asp
US
Hope that helps
Aug 27, 2011 | Troy Garden
The motor runs but the trimmer head turns slowly or not at all.
The problem may not be in the clutch assembly, if you took the engine apart you would have noticed a lot of debris if a lining had been stripped off. I would start with the lower flexible shaft assembly. This is probably where you will find something that is noticeably worn.
Here is a link to a Owner Manual / Parts listing. So you can see what the pieces should look like.
http://dl.owneriq.net/3/3e126dac-25ea-6974-e50f-90c9e8b1387a.pdf
If the link doesn't work here's where you can download it for free.
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/tb475ss_4.html
Feb 11, 2010 | Troy Garden
Troybilt 4 cycle trimmer (TB475ss) won't start. New tank, new plug, new gas??? Will occasionally start, run for about 10-15 secs, then stops. Won't restart. Help!
Sep 12, 2009 | Garden
Can not remove troy bilt weedeater head
Once all the bolts are removed, tap all the way around, (with a rubber mallet), where the head meets the bottom portion of the motor. It should come right off with a little coaxing.
Jim
Jun 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Garden Logo
197 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
