Hi!
Error F 02 means the drain time is taking longer period then normal. If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is flashed. To resolve the issue you are facing with you need to follow these steps---
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the ‘sud’ error will be displayed, then 4 minutes later the F/02 error code will be displayed.
To clear this error code—
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
If still the error code exists then you need to replace the pump.
Thanks for using FixYa and revert for further assistance.
Thanks
Rylee
