1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
hi anybody.i need help as my sony turntables arm has no end on it which i need a stylus.the arm ends...
(More)
hi anybody.i need help as my sony turntables arm has no end on it which i need a stylus.the arm ends with a silver bit with a hole in it.i don;nt know where to go or what to do to fix it.hope someone can help.thank you. SEAN
Runs at uneven speed. Drive band came off of the table. How is it supposed to be installed? Is the...
(More)
Runs at uneven speed. Drive band came off of the table. How is it supposed to be installed? Is the drive band supposed to be looped around the brass spinning post somehow? When it is just put up on the drive post the turntable runs too fast. Thanks
