Question about Samsung CLX-3175FW Multifunction Laser Color Printer
My printer is 5 weeks old. My Samsung CLX 3175FN color laser printer has a paper jam. I have removed as much of the paper as possible, but it is still jammed ( where I cannot get at it ) in the upper rear of the printer. I live in zip code 63366. where is the nearest repair shop ??
  • doug_noe Nov 20, 2009
    I had to call a Samsung tech for a service call.
    He had to disassemble the entire printer - to clear the jam.
Have you turned the printer off then tiurn it back on. If you have a paper jam, after you remove the paper, you must restart it for it to clear.
Otherwise, if there is paper still in the printer, turn off the printer remove all 4 toner cartridges and the waste cartridge. Once you do that you may be able to see the paper. You may be able to take one more thing out to where you can see the paper better, I am not sure.
Kevin
Posted on Nov 20, 2009
  • Christine Mcgrow
    Christine Mcgrow Jul 03, 2016
    thanks a lot it worked for my m2070
    President:
  • 2,306 Answers
Call Samsung for the nearest shop, 1-800-849-2198
Posted on Jul 20, 2009
Clx-3175 laser printer always results in a paper jam -why? how to fix it? Help help please
first remove the power and remove the cartridge cover and inspect for tiny piece of paper remove the piece of paper or you can use an mild air blower to flush it out for that first remove the toner and use the air blower and clean the inside of the printer if there is any tiny piece of paper the paper get jammed often
Oct 26, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
I cannot print heavy paper. It consistenly jams. My HP inkjet prints the same weight of paper easily. Suggestions?
The maximum paper weight that should be used on the CLX-3175 is 163gsm, so if you use thicker paper it would jam.
Jun 04, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Printer says "scan unit open or paper jam 2" Hav...
Dear
The printer paper jam-2 cover may be opened or not locked properly.
This door is at back side of the printer.
Thanks.
May 21, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Paper Jam 1 error for a CLX3175 FN multi color laser printer
Just pull out the drum, and clear the jammed paper and insert the drum back, it will work fine
Apr 30, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
I can'r find the paper jam in the printer. screen
If not picking up the paper then it the Pick-up Roller just above where the paper tray is. Remove the paper Tray and Tip Printer back so you can see under the Printer. Take some rubbing alcohol and clean off the rubber roller
Service Manual found here Free...
http://hotfile.com/dl/28988134/55113fe/CLX-3170-3175.zip.html
Feb 09, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Paper keeps jamming when printer warms up on my samsung CFX 3175FN
Hi. can you try to lift the printer and turn it upside down. it is mainly caused by paper clips.
Jan 26, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Constant Paper jams on CLX-3175FN
The fact that there appears to be no actual jam tells me that it is not picking up paper out of the tray. Try some alcohol on the pickup rollers, rubbing well. If that helps, replace these rollers.
Aug 12, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Samsung color laser MFP CLX-3175FW. Paper jams after the first page is printed and continues to jam each subsequent page. This is the third printer we have tried. Using a MAC computer. Suggestions...
clean the pickup roller that feeds the main tray.
This is an ongoing problem with this printer, even in the single function printers.
I used a toothbrush and water, scrubbing horizontally.
Jul 05, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Samsung CLX-3175FW Multifunction Laser Color Printer Logo
241 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
