Estate Washer will not drain (model: SM 8280867) appears to have a damaged sensor on the lid, need info on how to access this piece, also need info on how to access the pump if this is not the problem
  • Mike Smith
    Mike Smith May 11, 2010
    Need correct model number off washer .
  • 5,911 Answers
If this is an Estate top loader, check your lid switch. Since the pump is mechanically driven, it usually is not the problem unless it is clogged. The washer will still run, though, if this were the case. This problem is commonly attributed to a loose or broken lid switch.
If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
NOTE: Some washer models have the lid switch located near either the left or right hinge of the lid. This type of switch is activated by a rod on the hinge pin. If not functioning, it can often be adjusted by bending the hinge rod until it engages the switch.
You can access the drain pump by removing the washer case. The pump is located directly in the front of the washer under the wash tub. It has two hoses attached. All you have to do is remove one of the drain hoses to drain any water. However, before you do that try using a wet dry shop vac on the drain hose by pulling it from the standpipe at the wall and pulling a vacuum on it. This will minimize the need to mop up any water. These wash tubs have a capacity of about 35 gallons. That's a lot of water to bail or try to mop up. If the water drains with a vacuum on the line, the pump probably isn't clogged. NOTE: If the lid switch is defective, you do not have to drain the tub to install a new one. The water will drain once the switch is repaired.
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
PS Are you sure you have the model number correct? I tried doing a search on that number and it doesn't cross to anything. I think you may have posted the Serial Number. Please verify and post back with a correct Model Number if this is the case. I would like to be able to confirm how your washer is configured.
Posted on Jul 19, 2009
  • 240 Answers
The lid sw is the most likely culprit, the drain pump is attached to the main drive motor on bottom, and turns whenever the motor is running. This is almost never the problem unless clogged. The lid switch varies based on age. newer models have no visible switch parts and are hidden under the console on the left side actuated by a arm from the hinge. older models (more likely to have a broken lid sw) have a pin on the lid which depresses a switch on the right side of the opening. Find the two philips screws on rear of console going down to top, loosen (they wont remove) and pull console forward and fold back on rear hinges. remove two brass clips holding top to back panel. pull cabinet away from machine (note how side sit on base with hooks and front is under base) switch body is attached by philip screws, harness is cliped to side, connecter is snapped in place. new switch has attached harness and connector. There are different harness lengths and connectors based on model. top is screwed to cabinet
Model # SM 8280867 How old is this model?
6 - 10 years in 2012
Whirlpool Washer Ultimate Care ii - Appliance Repair Forums www.applianceblog.com/.../32099-Whirlpool-Washer-Ultimate-Care-ii
  • LAST UPDATED: 2012-05-28
  • 6 POSTS
  • FIRST POST: 2012-05-28
Whirlpool Washer Ultimate Care ii Model Number: SM 8280867 Brand: Whirlpool Age: 6-10 years Hello, The washer ...
Jan 27, 2016 | Washing Machines
Whirlpool type 107
Sounds like the clutch may be slipping. Does it go into a high speed spin?
Aug 18, 2013 | Washing Machines
Washer fill with water model # LA4800XTW0 then just sits there no agiate no spin water will then drain once switch is manually advanced. Lid switch problem? OR direct motor coupler?
Hello, welcome to FixYa.
Based on your post, if you mean manually advancing the timer it will drain, it's a coupler. If you mean manually activating the lid switch, it is the lid switch or lid switch strike.
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-load washer, not necessarily applicable to ALL...based on the model provided, it cover's yours)
Thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Aug 14, 2011 | Whirlpool Washing Machines
14 year old Whirlpool Estate washer. leaks small
Most likely you have a leaking water pump. This is not too hard to change if you are somewhat mechanically inclined it is around a 5 on a scale of 10. Your model # should be on the back of machine towards the top. If you want to change it yourself let me know and I will give you directions. Let me know if I can do anything else to help.
Mar 18, 2010 | Washing Machines
Estate taws700rq1 will
Check your lid switch. If the washer fills and agitates, but stops at the rinse cycle, or, if the washer fills, then stops and will NOT drain, this is a common symptom of a lid switch malfunction. The following link explains how to access and/or replace one:
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
repairclinic.com
The part number for the model you have listed is 8318084. The average price is about $15 - $25. Prices differ between these sites, so shop around for the best price.
This is a very simple repair, but if you have questions, please let me know. If your symptoms differ from what I have described, please post back and elaborate a bit more, so that I can provide you with better assistance. I hope this helps you.
Oct 29, 2009 | Washing Machines
Water won't drain, how can I open the the washing machine
I would recommend checking your lid switch. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If not activated by a lid strike, other models have the lid switch located under the washer casing next to one of the lid hinges. It is activated by a rod contacting an actuator. The mounting scews for this type are located under the operator console.
If you determine the switch to be defective, the following link explains how to access the washer interior and replace one:
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. NOTE: Since you posted no brand name or model number, the instructions I provided the best instructions I have. These steps are for any Whirlpool manufactured top loader. This includes Kenmore, Estate, and Roper. If you need further assistance, or if your brand name is not included, please post back with your model number, so that I may assist you better.
Aug 15, 2009 | Kenmore 24032\24036 Top Load Washer
My Estate washer will not drain.
Hey Don, If you removed the cabinet to get to your pump, you had to unplug the wire that connects to your lid switch. Did you make sure to plug the lid switch plug back into it's plug-in on top of your cabinet under control panel when you re-installed the cabinet. Your washer won't spin or pump water if this is the case. I'd check that first, then check the lid switch itself for proper operation. Happy to help, Tim. please don't forget to rate my help. Thanks.
Jun 28, 2009 | Estate TAWX700JQ Top Load Washer
Washer will fill up but wont agitate, spin or drain
This is a typical symptom of a defective lid switch. As you open and close the washer lid, you should hear a "clicking" sound. If you do not, the lid switch is probably loose or broken. The lid switch is located on the right hand side under the washer casing rim. It is activated through a small hole by a plastic piece on the lid called a lid strike. If this piece is broken off, the lid switch will also not activate. Inspect the switch mounting screws (two of them on along the wash tub rim) and make sure they are tight, and make sure the lid strike is in place. If you need to replace the switch, click on the following link for step-by-step instructions:
http://www.fixya.com/support/r397101-replacing_lid_switch
If you require replacement parts, you can find them at searspartsdirect.com. Just type in your model number and the you can find the lid switch listed under the "Top and Cabinet/Literature" heading as item number 9 (part #3949247). The lid strike is item number 20 (part #358684). This is a simple repair that you can accomplish yourself and the cost is minimal. If you need further assistance, please post back and let me know. I hope this is helpful to you.
Jun 16, 2008 | Estate TAWX700JQ Top Load Washer
Washer estate brand ETW4300SQ Model
If the washer fills and stops at the rinse cycle, and then will not spin or drain, you more than likely have a defective lid switch. If you open and close the washer lid and do not hear a “clicking” sound, the switch has probably come loose, or has broken. There are two mounting screws that hold the switch in place along the washer rim. Also, inspect the lid to ensure the small plastic piece that pushes down on the switch when the lid is closed has not broken off. This is called the “lid strike”. If the lid strike is broken or missing, the lid switch will not activate. If you diagnose the problem and need to replace the switch, you can click on the following link for advice on how to replace it:
If you need further assistance, such as where to get replacements parts, please let me know. I hope this helps you.
NOTE: You do not need to drain the wash tub to replace the switch. Once the switch has been replaced, the washer should spin and drain, which will prevent you from needing to bail water.
May 23, 2008 | Estate TAWB600JQ Top Load Washer
Washing Machines Logo
2,044 people viewed this question
Top Washing Machines Experts
