Question about Sony DCR-HC38 Mini DV Digital Camcorder
Tape holder will not close
Tape holder will not remain closed (needs weight/force to stay in shut position) or lower self into camera. Camera says to reattach power source and flashes c:32:11. I tried all things manual suggested surrounding this warning display, but have the added issue of it not closing.  I tried other suggestion posted for similar issue to no avail as well.
  • anafilippo Sep 01, 2009
    Still have not. Am considering biting the bucks to send it in and be fixed.
  • 3 Answers
I am no longer a Sony product fan - this is the most unacceptable performance of any of their prodducts I have ever attempted to use. I have NEVER been able to record ANYTHING with this. The very first cassette - gave me the 'moisture' flashing symbol, and the cassette would not eject. Then after reading a recommendation on this board, I removed and reinstalled the battery a couple of times and the cassette finally popped out - now it won't accept the cassette and close - PLUS will not accept my normal NPfh30 battery and keeps telling me to reattach the power source. and after nummerous tires and camera resets, tried the NPFH100 battery and it tells me that I can not use this battery in the camera. I still get a C:32:11 code and so far this is a non-functional - malfunctioning POS
Posted on Nov 27, 2009
How did you fix it
Posted on Aug 08, 2009
Help me to turn on my camera to access my media card.
You do understand that to open the battery cover you slide it out and then up. To close the cover it must be in the out position when you close it and then slide the cover in. If the cover is broken you can put it in position and tape it shut.
Nov 09, 2014 | Fuji Finepix A610 Digital Camera
Battery door won't stay closed on Sony Cyber-Shot DSC-S90 Digital Camera
The battery door latch is most likely damaged/broken. Try using a piece of duct tape to keep it closed. I've done this on several cameras with battery door latch issues & the doors stayed shut just fine.
May 20, 2014 | Sony Cyber-Shot DSC-S90 Digital Camera
Hi. I open the top to insert a tape, and after the tape holder opens, the camera bleeps five or six times. If I insert at tape, and close the holder, it starts to load, then bleeps a few times and...
This sounds like a run motor issue and will require major disassembly to repair and can be done fairly inexpensively. However, it's not really a user serviceable problem and should be done by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have it repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Sep 25, 2011 | Canon HV20 HDV Digital Camcorder
The door that holds the batteries in will not stay shut i believe maybe where you slide it shut a piece of that might be broken is there anyway to fix that or do i just need to hold it closed and hope for...
Pull the batteries out and see if it will stay closed, if it does the batteries are installed incorrectly. If it still won't stay closed your options are to either tape it shut or get a new camera unless it is under manufacture warrenty still or you have an accidental damage plan.
Jul 28, 2011 | Olympus FE-210 Digital Camera
Tape ejector won't stay closed on CCDTR67 NTSC Sony Handycam
This equipment is almost twenty years old - time to replace it.
May 03, 2017 | Sony Handycam CCD-TR67 Camcorder
E04 unit in safeguard mode
I tried every method I could find from people posting on the web, but the method that worked for me is this.
1. Eject the tape and close the tape holder.
2. Turn the camera off and remove the battery.
3. Put the battery back in. Leave the camera off.
4. Open the tape holder.
5. Slide the tape in, but as you press the holder in to accept the tape, keep your finger pressing in on the holder, being careful not to slow the tape holder from moving downward.
6. Turn the camera on.
7. If it doesn't work the first time, press more firmly to help the tape holder accept the tape.
That's it. This method seems to work for me and lets me use the camera for a long while. If the camera is sitting unused for more than a few hours, I have to do it again. And each time I insert a tape, I make sure that I keep pressing as the tape holder lowers the tape.
Mar 27, 2008 | JVC Cybercam GR-DVL805 Mini DV Digital...
Fujifilm s5000 I want to buy a new battery door. Is that possible?
I have the same problem and after many different contraptions to try to keep it closed I simply used a ponytail holder. Just a simple brown hair elastic. (a large one) It has worked well for over a year now.
Feb 23, 2008 | Fuji FinePix S5000 Digital Camera
Cassette holder does not close
Try inserting another tape first. If the trouble is still there,Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Aug 20, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sony DCR-HC38 Mini DV Digital Camcorder Logo
903 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
