Question about Maytag Washing Machines
Neptune washer stops before going into rinse cycle
My neptune washer stops just before entering the rinse cycle. When I push the start button it starts back up and then runs through the cycle. I have already replaced the wax motor and components on board that fail when it does not spin. I did this about 1 1/2 years ago and it ran great until now. Any Suggestions?
Thanks
  • 3,230 Answers
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It also may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Check it out....
Best of Luck!!
thanks
Posted on Jul 19, 2009
Washer wont go through the cycles... it stops working before the final rinse cycle
MAH5500B Maytag Neptune washer stops and I have to put back into star and not just wash one side wet clothes and Susie sige water drains can only hear a buzz and it takes many items and each shaved marked "nf" and "Lf"
May 29, 2011 | Maytag Neptune MAH5500B Front Load Washer
Stops during rinse cycles. i have to press start button for each rinse cycle because it keeps stopping
It sounds like the timer has a bad spot in the tiny gears. May be able to find a cheap timer on ebay.
Oct 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
When it gets to a Rinse cycle position on the dial it simply stops. If you push the Start button then it continues with the Rinse. We replaced the circuit board about 8 months ago for another problem.
check the circuit board again front and back look for burns ---should also replace the door lock assembly it is the cause for most machine control board failures
Jul 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer
LR == locked rotor, which translates to a bad motor and motor control board( usually depending on age sold a 1 set. Neptune repair kit. retails for about $200 part number 12002039
Oct 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
MAH3000AWW Trips 20Amp Breaker at rinse cycle
The motor is known to have bad windings. Do a search for "Neptune Washer will not start" Also just inside the control panel where the start/stop sw is should be a paper folded with the diagnostics test and schematic. It is tucked under the pressure sw attached to the back. If not there then search "Maytag Neptune motor phase test" There is also a Service Manual FREE at Goetlieh's site.
Sep 27, 2008 | Maytag Neptune Washer
Maytag washer shutting off on rinse cycle
If the washer is not completing the Rinse cycle there may be problem with:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Let me know if you need further assistance.
Regards
Ellin
Sep 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
MY NEPTUNE MAH4000AWW WORK WHEN IT WANT TO WORK
Check for low water pressure. Clear screens in inlet valve. Do-not remove screens. This unit will turn off if not filled in specified time.
Nov 08, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
99 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
