Question about Kenmore 53542 / 53544 Side by Side Refrigerator
No ice I have a Kenmore Coldspot M/n 535423 and it doesn't make any ice. water dispenser works fine, but no water goes in the tray. Only 1.5 years old!
  • iceless Nov 20, 2007
    Hey,
    Thanks for the quick turnaround on diagnostics suggestion. I'll take a look and rate the sol'n.
  • iceless Nov 27, 2007
    You hit it exactly. One of the plastic tabs was broken and I simply epoxied it back on (simply to confirm you're diagnostics) and it worked. I'm guessing that it will eventually break off, but now I know. Thank you very much.
If you remove the icemaker there is a white cover over the head of the icemaker, pull the cover off. youll see a gear in the center. in the middle of that gear there are two plastic tabs that hold it in place one or both of the tabs may be broken cause a bad conection behind the wheel. if tabs are broken you need a icemaker modual (part the gear is attatched to) if not broken you need a watervalve located on the bottom right side behind the freezer
Posted on Nov 19, 2007
My Kenmore Coldspot mdl#106.53359300 icemaker isn't making/dispensing any ice, help? Is there a reset button?
No. Need more details. Is water entering the tray? Is ice in tray but not coming out? Clarification needed for help!
Jun 06, 2016 | Kenmore Refrigerators
Ice dispenser not dropping ice using dispenser knob
If you can hear the auger motor turn, you may have a large chunk of ice in the hopper.
Jul 25, 2014 | Kenmore Refrigerators
My icemaker quit working. Water does not come in to fill the tray. Water source is turned on. In door water dispenser works fine. What should I do to troubleshoot? I don't hear the solenoid click in...
have you checked the inflow tube to see if it's iced up? if your icemaker isn't filling with water and your getting water in the dispenser your feeder tube is probably frozen
Apr 11, 2011 | Kenmore Side by Side Refrigerator
Kenmore Coldspot Ice Maker Modle #106 56622500 I
these have to be in correctly to lock back in and allow the unit to function. Try removing the bin again and be sure there isn't any small pieces of ice trapped anywhere. Also make sure there aren't any broken pieces from the bin. Hope this helps. Good luck.
Aug 18, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Coldspot 10650522100 - water not getting to icemaker
look and inspect closely why the water is not going down the ice tray. maybe the soft hose to lead the water down to the tray is kinked or broke.
check also if there are still ice in the tray, they could have not dropped yet that is why water is just overflowing on the tray.
tnx 4 using fixya,
drcool
Sep 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
I have a kenmore coldspot side by side model # 106.53662300.
The ice maker red light is blinking and it has made very little ice in the last 24 hours. What do you think the problem is?
Jan 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Just above the tray that holds the ice cubes is a wire bar. If the bar is down, it will make ice. If the bar is up, it will stop making ice. When there is enough Ice in the tray, when the bar comes downm, it will hit the ice. If the bar is not completely down, no ice will be made.
I bet the bar is stuck, or you don't have a water supply to make ice (or it's plugged - de-ice the freezer).
Richard
Jan 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
there is some times a water relay that turns the water on and off the over heats, it located in the back where the water connects
Dec 08, 2007 | Refrigerators
Kenmore 53542 / 53544 Side by Side Refrigerator Logo
174 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
