Question about Boating
Water pump empeller replacing 1960 40hp
Replacing the water pump impeller, can't get the lower end to drop. unbolted lower end and shift shaft but drive shaft will not drop.
  • cjdd1 Jul 25, 2009
    Good Job! That's what the dealer told me. But, I read that on the shift shaft all you had to do was loosen the bolts,when in fact you have to remove all the way. Fixed! Takeing out tomorrow for 1st. run on 1960 13 ft. flat bottom. Thanks, I'll be back!
  • 677 Answers
On an old motor,the problem will be that the shaft that runs from the crankshaft to the g/box may have frozen .The shaft has a splined fitting that goes into the bottom of the crankshaft.These have a habit of fusing together.It can sometimes be a problem to get them apart.1st try is to unbolt the power head and put some gentle heat onto it.The fused part (bottom of the crank).2nd is to turn the crank and with a soft striker(eg copper or zinc shaft)striking it all the way around the fused point,maybe 10 or 20 times.Then try the heat again.Its a long process but cheaper than having to buy new stuff. Hope this helps
Posted on Jul 23, 2009
Removing impeller from OJ800 water pump
The impeller has a reverse thread locking screw through the center. You can secure the motor shaft by putting a 9/16 open end wrench on the other end of the shaft, which is under a cap in the middle of the rear of the motor.
Check your seal plate carefully. Whisperflo is a great pump but they don't take heat very well. It is very common for the seal plate to also be damaged when the pump runs hot, particularly the lower inserts where the bolts screw into.
Jan 05, 2014 | Pentair 1 hp WhisperFlo InGround Pool Pump...
1977 9.8 hp Mercury Outboard Motor Serrial # 4605112, it's an electric start with a short shaft
put it in forward gear. Drop the lower off by releasing the bolts and nuts holding it holding the lower on. (one is hiding under the back pick up screen)- some models had a plug in the back top of the exhaust/intermediate housing hiding an allen head bolt pointing down.
Once released, put a protector in a vise and clamp the lower to the bench.
2 screws or bolts will hold the water pump cover on. (the drive shaft runs thru it) Clean the carbon and rust off the drive shaft will allow the pump housing and impeller off the lower. Retrieve the funny looking key drive which runs the pump.
Inspect the shaft, the lower unit oil for water. and find all the pieces of the water pump impeller which may have gone places they shouldn't have.- including the outlet tube from the power head. Check this by putting a tube on the end and blowing- you should hear and feel the pressure in the exhaust and tell tale hole.
Now take the model number , the old pump parts to the marina for a replacement. Do a side by side comparison at the marina so you get the right stuff. Check the inside drive of the rubber impeller and see if they are exactly the same.
NOW- put the new wear plate / gaskets and drive key on, hold in place with grease. Slide the impeller on the key and spin the drive in both directions to be sure it has the impeller and will securely turn it.
Put grease in the cup of the pump housing to prevent dry start and help seat the impeller blades. Spin the shaft as you lower the housing in the pump so the blades all face in the right direction (clockwise). Screw in the bolts. Grease up the seal the watertube goes in and the spline end of the drive shaft.
Up the hole it all goes, now you only have to spline the shifter (it hasn't moved has it?) The drive shaft and the water tube all at the same time.
Check the shifter for correct position and bolt it down
Jul 28, 2012 | Mercury Mark 30 Hipo Outboard Motor...
Water pump not working on Johnson 3.3 outboard 2 stroke.
sounds like you need a new water pump impeller.
to access the impeller the bottom of the motor needs to be unbolted and the impeller is fitted to the shaft, it is keyed so it only goes on one way. ( impeller kits will come with new gaskets,grease.O-rings and a new key ). re-bolt the lower unit and test.
c...
Jan 01, 2011 | Sport & Outdoor - Others
1997 Evinrude 50 HP SPL. I have removed all the bolts holding the lower rnd to the engine, it seems to be hanging up on the shify shaft, and I can't find a way to drop the unit. It drops down about...
Okay this is on total memory. The shift shaft for a lot of those engines goes right up through the pilot shaft and exits just in front of the block under the carburetor(s). You will see the **** linkage arm connected to this shaft sometimes it's double nutted. See if you can slide the lower unit back up to the housing and put a bolt in it to hold then undue the shift shaft linkage, Remove the bolt and drop the lower unit. Be careful of the water tubes and check make sure the rubber grommets are in place in the pump housing not on the tubes. Clean up the pump housing and install the new impeller kit.
Put the impeller down the shaft on top of the impeller plate, lightly grease the inside of the housing the impeller plate and impeller. Then lower the pump housing down to the impeller while turning the drive shaft clockwise lightly push down on the impeller housing. This will fold the impeller blades all in the correct position and provide lubrication to the pump until the water gets into the pump. To make life easier re-grease the drive shaft spline and the water tube grommets this will ad ease in reinstalling the lower unit. be careful to make sure you thread the drive shaft, water tubes and shift shaft all in at the same time. After installation you may find you need to adjust the **** linkage.
Dec 11, 2010 | Boating
I cleaned the trap but the empeller sounds as is it hitting sometheing but I was not able to feel anyhing around the empeller. pump motor seems to be running hot and smells as if it burning
Replace your drain pump. It does not take much to damage these small drain pumps. If anything was lodged in the pump reservoir for any significant period of time it could have damaged the impeller blades, impeller shaft, or pump motor. So, if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may experience drain error codes if the drain cycle exceeds 8 minutes. If this occurs, you will have to replace the pump in order to get any errors to clear, or the washer will not complete any cycles. The following link explains how to replace the pump:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
A replacement can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need. If the model number is correct, the part number is 280187. The pump comes as a complete assembly and parts cannot be purchased separately.
NOTE: For a full explanation of all the error codes, each one of these appliances come with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided, and if you require additional assistance, please post back and let me know.. I hope you find this information helpful.
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How tough is it to change water pump impeller on 15hp johnson
There is no special tricks.Unbolt the gearshift linkage that has access through the side of the leg.Usually a small plate.Unbolt the lower g/box.4 bolts I think.The box should then drop.If not,use a rubber hammer and be patient.Put the lower skeg of the g/box in a vice to make things easier.NOW.When you lift the housing of the w/pump take a note of which way the impellar pump lobes are curled.DON'T put the new impellar in the wrong way.It's probably worth putting in a new seal whilst it's apart.You spin the housing or imp. as you put it together.Use a small bit of grease for the initiall dry start-up.Put some very good grease on the top splines on the driveshaft.It goes straight into the crankshaft.If it corrodes,nothing comes apart.As you put the g/box back on,spin the prop so the splines go back in.There is no special alignment.Gearchange linkage and you go fishing.(take the prop off and regrease the splines on the shaft of it)Hope this helps
Jul 22, 2010 | Boating
How to replace water pump on a 1985 90 hp mariner outboard motor
mcdevito75 Here, If I;m not mistaken the water pump is in the lower houseing, a big job, let the marina take care of it as the water pump should be Changed only if it doesn"t pump at all.
Jun 16, 2010 | 2004 Mercury Mariner
I would like some advise on how to replaxce an impeller on my merc 150 hp year 2001
Replacing the impeller is fairly simple, The only thing to watch for is the shift link that goes into the top, some of them have to be unscrewed and you have to count the turns and put it back the same amount of turns. It will not shift if you don't. Your's might not have this, but just drop the bottom of the motor, the water pump sits right there, sometimes it doesn't even look bad. Make sure you have enough room to get the shaft out of the engine before you hit the ground. The shifter has to be unbolted at the top.
Feb 24, 2010 | Boating
How do you take the empeller off the shaft to put it on the new m
Take the back of the motor off, just a cover, you should find a flat spot on the shaft to fit a wrench, hold the shaft and spin off the Impeller.
Feb 20, 2010 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
How do i change the lower water unit on a 40 hp 2 stroke mercury motot
You mean the water pump? It is fairly easy , You have to drop the lower unit, a long shaft is attached that goes up inside the engine, I haven't done this in a while, I'm trying to remember, I know that the shaft had threads on it, and you had to count the number of turns, to get it to shift right. That was the hard part, change out the impeller, new rubber, new plate, You are all set. If it is the lower unit you want to change out, It is basically the same, but all those parts in there are replaceable. If the bolts are frozen, get some "blaster" on them and let them soak.
Feb 20, 2010 | Bass Pro Boating
Boating Logo
96 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
