Question about Samsung SYNC SGH-A707 Cellular Phone
Dropped in toilet
My # 8 key sticks and battrey doesn't hold very looong
i had the same problem and all i did was put my phone and battery in a box full of rice;)
Posted on Jun 03, 2008
  • 4,102 Answers
The problem with this make of phone it is difficult to take apart but it sounds like you have a corroded board where the buttons are this will need cleaning as with the battery it might need replacing have you let the battery go totally flat so their is no power in it at all then charge from flat you are supposed to do this every couple of months to prolong the life of the battery i would sugest you dont take phone apart yourself as you could warp the board and the phone would be irripairable hope this is some help to you good luck.....................................
Posted on Nov 19, 2007
Toilet Cistern Sticking
Mechanism that releases and shuts off water should be checked if any part has disconnect or improper connection.
Jul 09, 2013 | Home
Jabsco electric toilet won't flush
Check the power source to toilet and all wiring conversed.
Sep 07, 2017 | Jabsco Home
After flushing, the toilet keeps running. However, if I turn off the water supply, and then turn back on, the toilet stops running until the next time it is flushed. Toilet makes a
It could be the type of flap you are using. I would suggest you try a different shaped flapper (a cone would work best) and if that doesn't do it, put a new kit into the unit, because it could be that the float system is sticking causing it to continue running.
Jan 10, 2012 | Toto Carlyle One-Piece Toilet Toilets
When i changed the battery the watch says error so cannot set time battery lite flash on of recall button seems not to be all the way out out watch is lance 4 thanks
Press and hold 4 buttons on the four corners at the same time for 3 seconds to reset the watch after battrey replacement. check the last page of the manual for the same.
If it doesn't help then try another new battrey.
Sep 19, 2011 | Nike Lance Armstrong Limited Edition Lance...
Hinge on quiet close stopped working
A lot of these slow closing toilet seats don't work well, so I suggest an alternative, Drop-a-Seat cushions. They stick on to the bottom of the toilet seat, allow you to drop any toilet seat, gravity does all the work, and the cushions absorb the impact. They're non-absorbent, stick on for easy installation (permanent yet removable), and are only $4.99. Check them out at
Aug 14, 2011 | Kohler Toilet Seat - Elongated Front Quiet...
After the toilet is flushed and the water in the tank drops the floats drops but even with additional downward pressure water doesn't fill up the tank in earnest.
ok...first turn off the water supply at the shuttoff valve under the tank(presuming you have one if not shut the water off some how) disconnect the supply line from the flote valve and hold it into a 5 gal bucket while you turn the water back on slowly. if you are getting good pressure from the supply line then the flote valve is bad or has been obstructed by foreign matter.
Jul 25, 2011 | Fluidmaster Plumbing
The slow-lowering lid has reverted to slamming - can i just tighten the bolts to fix it?
If you want to be able to just tip the seat and let if fall without that loud slamming clank, look into getting some Drop-a-Seat cushions, a brand new product that is only $4.99 and absorbs the fall of the toilet seat and eliminates loud clanks. They're non-absorbent, have an easy stick-on installation, and are permanent but removable.
Feb 24, 2011 | Toto Carlyle 1-piece Elongated Bowl Toilet
How do you replace the seat?
To replace seat. look rite at where the lid hinges there is like two block abour 6 to 8" apart. take a small screw driver and pop free the lil door covering the srew head. take a big philps or straight head screw driver. and then look under neath where bolt would stick out below. and you will see a nut,you should be able to hold nut by hand as you titen the bolt. both nut and bolt are plastic. draw good and snug. hope this helps. duane.
Sep 29, 2009 | Kohler K-3384-2 San Raphael Elongated...
American Standard Elongated toilet bowl water level slowly drops
The tank holding the proper amount of water is a good sign. The inside of the stool is like the GOOSE NECK under you sink. It always holds water. This may sound like a bit of a hassle to do but if all 3 toilets are identical, here is what you can try if you are a bit handy. Go to the hardware store and purchase 4 toilet wax rings with a plastic flange and a few sets of toilet floor flange bolts(they are cheap and you can always return if not used, as It is better to have xtra parts on hand). Turn off the water supply to the "Mystery Toilet". Leave the tank and everything connected to the stool. Flush the toilet and remove all excess water from the tank and bowl. This can be done with a shop vac, sponge or towel. Disconnect the water supply to the tank. Remove the bolts holding the stool to the floor and carefully remove toilet. Scrap off all the old wax from the floor flange and bottom of stool. Now go and repeat this proceedure to one of the toilets that is working properly. In other words Switch the "Mystery Toilet" with a "Working Toilet" and see how they react. If the working toilet does it in the same bathroom and the "Mystery Toilet" does not do it in the other bathroom then you probably have a VENTING PROBLEM. If the "Mysery Toilet" Does it in the other bathroom then you most likely have a Defective Toilet. This Job is best done by 2 people, as it can sometimes be challenging to center the new wax ring on the toilet flange. Reconnect to the floor and reconnect water supply to the tanks. DO NOT OVERTIGHTEN BOLTS to the floor flange as you may crack the toilet. All drain lines must be vented properly for water to flow. If you are curious check out drain venting on the internet. Also, sometimes a vent can become obstructed with debris, ice, bird nest, etc.. I would 1st check the vent on the roof visually and then have someone flush and listen. If you believe the vent is clear....Then do the toilet switch and go from there.....Hope this helps and Happy Holidays....Joe
Dec 21, 2008 | American Standard Cadet 3 Right Height...
Samsung SYNC SGH-A707 Cellular Phone Logo
29 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
