Question about Panasonic PT-AE900U Multimedia Projector
Panasonic PTAE900 red vertical lines have appeared constantly
Basically im not very technical when it comes to opening up electrical equipment. Need to send my projector to Panasonic to get this problem fixed but they cant tell me how much it will cost until they open it up. Problem is i have to pay them £75 + vat for this to happen. I already need a new bulb and weighing it up i might aswell buy the newer 200e (which i really cant afford).
Has anybody had this problem fixed by panasonic and if so how much did it cost???
  • 3,267 Answers
Actually you have admitted that you are not handy with electrical equipment and the problem with your projector involves a little bit of soldering and a little knowledge regarding the internal layout of the components like IC's, heatsinks, etc. So I would advice you to send the projector to panasonic telling them specifically the area they need to fix, which is, to check the green & red IC's to identify whch pins have overheated and the solder has melted, causing a short. Also ask them to add spme extra aluminium to the heat sink(green & RED Ic's since they have a common heat sink). So you have to pay the service charge only since you are informing then where the problem is & its rectification. I think in this fashion you might get away by paying 75 pounds only which u have to part with if you want this item repaired, and fact is that it can be rectified, as stated above, making it the most cost effective solution.........................................sodeep
Posted on Aug 05, 2009
    Problem Solver:
  • 5 Answers
I solved the the problem with following hint:
http://www.fixya.com/support/t305560-even_spaced_vertical_lines_across_whole
Repair was done within one hour without any replacement parts but needs some experience and some equipment.
Posted on Aug 01, 2009
How to fix mirrors on NEC NP400 projector?
Hello there,
I know this problem all too well so my answer may be what you (and others) are looking for in the following thread: http://www.fixya.com/support/t25268267-get_rid_dark_shadow_across_top_screen
Basically what happens is a prism in the projector has become dislodged due to the cheap adhesive they use and the extreme heat it's subjected to. Some JB-Weld Steel Reinforced Epoxy will fix it right up. Just read my instructions in the above link.
May 03, 2012 | NEC NP400 Projector
I need a user manual for panasonic pt-ae200e
I can email you this manual. It is 34 pages. Please send email to LBrown18062@hotmail.com Please put PANASONIC PT-AE 200E in the subject line. I will send it to you right away.
Oct 16, 2011 | Panasonic PT AE200 Multimedia Projector
HI There, I have just bought a viewsonic pj559d from ebay. Refurbished working with no lamp. I bought a 'JP-UK Genuine Alternative Viewsonic RLC-036-JP Projector Lamp for PJ559D Projector ' and...
A 'genuine ALTERNATIVE', is not a genuine Viewsonic part, but that is unlikely to be the problem. Two choices, take it for professional repair, or send it back to the seller as not working as advertised.
Jul 23, 2017 | VIEWSONIC PJ559D Replacement Projector...
The projector would not turn on and had a flashing red light for the lamp. Knowing it was an older projector when we rented the building I purchased a new bulb for this projector. When I put the new bulb...
PROBLEM :-The power supply of the projector is faulty there is a transistor witch is switch 15 volts for the lamp drive board.
SOLUTION: Remove the upper cover with 6 screws back side of the projector.
remove main board and lamp cover with 7 screws.(show in the picture)
remove upper cover of the power supply and lamp drive unit with 3 screws.
remove power supply unit with 4 screws and 3 connectors and put face down on the table.
now you find the transistor no Q107 and replace with the transistor no 2SB710 is and surface mounted compunent(show in the picture)
fix it all as you open.
power ON the projector and enjoy
(doing very carefully This is a technical job)
Feb 05, 2011 | Panasonic PT-LB10SVU Multimedia Projector
Screen is yellow in the middle?
If the yellow area edges are sharp then the blue LCD is faulty and need to be replaced.
If the yellow area edges are not sharp and you get the multi color background in you image the your need service. due to dust on LCD panals the light is not pass on properly so you open the projector and clean the LCD block.
(cleaning of LCD block and other parts of the projector is a very technical job please very very carefully)
Jan 25, 2011 | Panasonic PT-AE1000U LCD Projector
Panasonic PT-LB10U do not work lamp ok ballast ok issue is with the power suplly that do not send 15v dc to the ballast need to fix the power supply it send 380 v dc to the ballast but do not have the 15 v...
You have to replace the transistor Q107 on the board ETXM519MBGB
this is pnp type but i can't find it on service manual.So if you don't like to make experiments replace the board.
Oct 21, 2009 | Panasonic PT-LB10VU Multimedia Projector
I can't project my image from my laptop to the projector..
A usb cable will not work that way--on your projector, it's used for data...you need to obtain a monitor cable which will plug into the vga connector on the laptop and into the connector on the projector (rgb in 1) or (rgb in 2) If you use the #2 rgb input, make sure the button IS NOT pushed in! If it is, the projector will be switched to OUTPUT mode on the #2 connector. Also, on the laptop, normal operation is "laptop only"...when you push the <alt F4> buttons, it should then switch to "laptop + external display(projector)", another <alt F4> push will give "external display only" mode. Then, another push will return you back to "laptop only". NOTE: Sometimes, you have to turn on the projector first, then immediately turn on the laptop--not to get technical but different equipment can get finicky about syncing up...just something to be aware of...
Aug 31, 2009 | Hitachi CP-X250 Multimedia Projector
Stiff Pitch Adjustment
What did you open up? The top of what? If you could be specific, I can direct you.
If your pitch is stiff, try spraying some contact cleaner or similar - DO NOT USE WD40. Use an electrical contact cleaning solution, such as CAIG DEOXIT or CAIG FADERLUBE both work very well, and are good for electronic contacts.
If this does not work, then maybe the pitch control knob/shaft is slightly bent? Any physical damage?
Other than that, there isn't a whole lot you can do, unless you replace the pitch control - Technics Pitch Control.
- OPTiC
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Feb 14, 2009 | Technics SL-1210M5G Turntable
Panasonic PT-AE900U Multimedia Projector Logo
721 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
