Question about HP LaserJet 1100 Printer
HP Laserjet 1100
Printer will print on Excel or Word but will not print items from the internet.
Tried the software site and the only software install available is for fonts, not installer disk.
Using MS 98.
  • 417 Answers
Try selecting the image you want to print by holding the left mouse button down and moving it over the text once you have done that goto file print select the correct printer half way down you should have page, pages, or selection choose selection and then print.
Hope this is of help to you please rate me
Cheers J
Posted on Dec 31, 2007
Excel sheet not print for hp laserjet p1007
Well, there could be a couple of things that can go wrong here. Usually firmware updates or re-installing drivers resolve the problem, but there is no firmware update for this model and i'm assuming you've tried the driver and other excel files work fine then that leads to a few other possibilities. First, is the file located on your hard drive? (if not, save it to the desktop, open it from there and try to print). Second, Have you tried to reboot your computer and printer? Try those first.
Jan 19, 2015 | HP Hewlett Packard LaserJet P1005 Printer
I need a full version driver for windows 7 and a HP 1100 laserjet
Try the HP WEB site for the driver.
You can download the HP printer drivers from their supportWEB site. Please click on this link and select your model printer to download:-
Mar 02, 2012 | HP LaserJet 1100 Printer
I want TTFSUB. GPD files for HP 1100 A
That's the print spooler files for your printer. Just uninstall the printer and reinstall the print drivers using the included software.
1) Go into Control Panel~Device Manager (Devices and Printers in Win 7)~right click on the HP printer and left click on Remove Device. 2) Reinstall the printer using the HP software that was included with the printer or go to the HP web site to download the software if you have lost the original disk.
That should do it.
May 19, 2011 | HP LaserJet 1100 Printer
Installed usb to db26F converter to use printer
Ok reinstall as Administrator, use "Compatibility mode" for install and the run .exe, also run software as Administrator. too. Often these devices, USB - Serial Ports are NO GOOD for a printer. Either install a real Serial Port. or get a new printer. Windows 7 will NOT help either, it doesn't like older equipment.
Mar 24, 2010 | HP LaserJet 1100 Printer
Driver installed, does not print!
did u get a test print when u installed it....
do u c the printer hardware installed in the Control Panel/Printers and Faxes/
if yes then check to see if that printer is the default printer selected (a tickmak will appear in front of that)
else uninstall the printer from the Control Panel and re-install
Dec 17, 2009 | HP LaserJet 1100 Printer
Unable to scan on HP Laserjet 3055 on Windows XP
Sounds like a software issue - U might try contacting HP but do not hold your breath. If machine is out of warranty they want nothing to do with you and will refer you to some forum or whatever. Or they might tell you to get a new scanner compatible with a newer OS.
Jul 02, 2017 | HP LaserJet 3050 Printer
LaserJet 1100 printing problem
did you select the correct printer on the print details screen? also try go to the conrtol panel and delete the hp prinret program then re install/download it on line from hp.also if when you get it going if it feeds more than one piece of paper at a time they make a kit to fix this{its a little piece of plastic}. also if you cant find the program in the cp you may have deleted it al ready, just go downloaded it. good luck..
Jan 14, 2009 | HP LaserJet 1100 Printer
We have a HP Deskjet D1320 printer. I can print my email, pictures and items off the internet, but cannot print any word documents or notepad documents. When I print an excel document, I get an incomplete...
I have a HP Deskjet 1300n printer. I can print my email, pictures and items off the internet, but cannot print any word documents or notepad documents. When I print an excel document, I get an incomplete page-the grid lines will print,and text garbage from a adobe program but not all the text. When I do a test print page, I get an incomplete text page, but do not know how to solve this. I have removed and reloaded the printer software-no improvement. There are no new drivers to be installed.
Sep 21, 2008 | HP LaserJet 1300 Printer
Continuous garbage text when connected to pc
In reading this HP forum I have found many other LaserJet 1100 owners who are trying to do the same thing as you.
Many of them recommend various cable solutions from Sewell. When you contact Sewell, make sure to specify your printer model, and ask what specific cables and/or adapters you need to make it work vis USB. They sound quite knowledgeable, and seem to have dealth with this before.
Mar 06, 2008 | HP LaserJet 1100 Printer
HP LaserJet 1100
well, you didn't say what operating system you are using i assume you are using windows xp. to install it you should not have any problems first make sure you connect the usb cable to your printer and to your computer then turn the the power on the printer and your computer should pick it. if you have all the current microsoft updates it will most of the times install the driver and you will get a message that printer is ready to use. if windows xp does not find the driver it will ask you for the driver. you say that looked on hp website and didn't find anything, well i did a search on their site and found a driver and an appliction software. copy and paste the link below to your browser and should take to the download of the software and driver just chose your operating system and it will take to the other link click on the red tab download and save it for just in case after it finshes downloading click on run if you have your printer pluged in when u run this file it recognize and install without no problems.
Sep 27, 2007 | HP LaserJet 1100 Printer
HP LaserJet 1100 Printer Logo
49 people viewed this question
Ben Johnson
