That is a screw determined in the feeding tube. Its work is to seize the meat pushed into the tube and handed it over to the cutting blade for grinding.Click here for more info Category 1 HP Meat Grinder
take the other side off and take it to a parts store and match it up. they will be able to match it for like to likeand cost you less than buying a full set.
Firstly I would check it is fully engaged. If it is, remove the food grinder and look into the hole. You should be able to see a square hole inside. Turn on the mixer, the square hole should spin, if it does not, one of the gears inside the head has most likely broken. To repair this you will need to take the head apart.
The other possibility is that I misread your problem and that the grinder is turning, but the meat wont go through the plates at the end. This is a common issue which happens if the blade is not put in the end of the grinder. The blade is shaped like a cross and cuts the meat when it reaches the end of the screw.
