Question about Hitachi DZ-MV730A DVD Camcorder
Error for record
I donĀ“t know what else to do. Please help me!
  • Anonymous Nov 24, 2007
  • Anonymous Dec 12, 2007
    i have the same problem, did anyone get a solution?
Ride Bus 78-3
Posted on Dec 15, 2007
I got mine to go with a good lens cleaner, just like the one for your DVD, but for your camcorder.
Posted on Nov 30, 2007
When I insert a DVD-RW disc in my DVD-VR375 it tells me 'this disc can neither be played nor recorded'. Why is this happening?
This message alert prompts you check and make sure that there is no dirt or scratches on the disc.If so clean the disc surface with a soft dry cloth and try again.Please don't use any liquids or solvents to clean the disc.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jul 23, 2011 | Samsung DVD-VR375 DVD Recorder/VCR
Hitachi BX37E error
You can try to clean the laser lens first with a q-tip and 99% alcohol. If that fails, you should take it in for repair because the laser lens mechanism may be out of line because of a bump. There may also be a dust build up inside that prevents the proper movement of the lens. This can be done at home too.
Oct 15, 2007 | Hitachi DZ-BX37E DVD Camcorder
Dear Expert, Warm Greetings ! I have a Hitachi DVD CAM - GX3300E, on switching it on with a disk inside, I get a msg "DISC ACCES". Even on using a new RW DVD Disk i get the following...
Sounds like your lazer is weak,if you have warranty send it back for repair,if not make sure you get a quote before fixing it might be expensive.Good luck!!
Jan 08, 2011 | Computers & Internet
Cannt play/record DVD's - keep getting "no read" error sfter inserting disk - nothing works - tried brand new discs to record on and even a new movie on disc! How do I correct no read error on...
Depending on the formats of the discs you tried, and assuming they are the correct ones for this machine, it sounds very much like a defective DVD drive and/or software within the unit. If it is under warranty take it to an authorised service agent/workshop for assessment to see if it needs a new drive or not. If it isn't reading any discs, and the unit is brand new, it would most likely be the drive which would be at fault.
Nov 15, 2010 | Panasonic DMR-EZ48VK DVD Recorder
Screen reads cannot read disc check dirt/crack/both-sides contrary/inserted correctly
Ultimately it sounds like the dvd drive needs to be replaced. The laser is weak and cannot read the data that is being sent back to the processor, that is if the laser is firing at all. I hope this helps
Sep 15, 2010 | Hitachi UltraVision DZGX5020A DVD...
DVP-NS30 shows "CANNOT PLAY" message when DVD inserted
Follow this procedure to troubleshoot if the DVD player cannot read or play the inserted disc.
  1. Ensure the inserted disc is compatible with the DVD player.IMPORTANT: Refer to the operating instructions supplied with the product for a list of compatible disc. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  2. Use a soft cloth to clean the disc.
  3. Examine the disc for any cracks or scratches that might be interfering with playback.
  4. Attempt to play another disc.NOTES:
    • If another disc plays in the DVD player, then the previous disc is faulty.
    • Some recordable discs may not play correctly because of the quality of the recording, the physical condition of the disc, or the characteristics of the recording device or authoring software used.
  5. Remove the disc from the DVD player.
  6. Turn off the DVD player.
  7. Unplug the power cord of the DVD player from the AC outlet.
  8. Let the DVD player remain without power for 1 minute.
  9. Plug the power cord back into the AC outlet.
  10. Turn on the DVD player.
  11. Insert the disc into the DVD player.
  12. Attempt to play the disc.
If still persists, its time for your device to get serviced.
Aug 01, 2009 | Sony DVP-NS57P
My panasonic DMR-ES 15 cannot read anymore!
There maybe a problem with the optic lens (dirt) try to clean it very gently with cotton, also the motor plate that holds the cd/dvd is not holding it very well so it not rotates at proper speed try to clean the both sides where the hole of the cd/dvd is when it´s inserted, if you think that you migth not have skills for that don´t do it.
Hope it help
Jun 25, 2009 | Panasonic DMRES15 DVD Recorder
Hitatchi bx35a... after recording no data
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Dec 03, 2008 | Hitachi DZ-GX3200A DVD Camcorder
You I bought also this piece of junk full of craft. The dvd disk can be read in my my but not in my pc. It cant be hook also in the PC. Dont buy it you will regret.
Aug 09, 2008 | Hitachi DZBX35A DVD Camcorder
JVC DVD Player/Video Cassette Recorder Model HR-XV2EK
try to clean your machine by playing a lens cleaner disc coz the lens might be dirt enough not to pick on data from the discs you play. if it does not work then isuggest you change the lens coz it might be weak
Aug 01, 2007 | JVC DR-MV1S DVD Recorder/VCR
Hitachi DZ-MV730A DVD Camcorder Logo
447 people viewed this question
Top Hitachi Video Cameras Experts
Mohamed Ismail
Mohamed Ismail
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
