Question about NEC LCD1735NXM Monitor
My monitor goes to sleep after a certain time when I'm in BIOS?
I don't think this is normal, when I try to run Memtest86 or Drive Fitness test(both test are booted before the OS), the screen goes to sleep and never wakes up.
And I went in the BIOS, and after a couple of hours, the screen was off(or sleeping)... I knew the computer was still on, so I did F10 and Enter(save and exit), the monitor came back ONLY after that.
What am I supose to do? I disabled everything in "power management" and every single screensaver related thing is the OS(Vista). What else is left?
My screen is a NEC LCD1735NXM my Graphic card is a Ati HD2600XT, I updated all drivers I found and my power supply is a new 450 Watt(80+ from BFG)
Thanks
Thanks
  • jimmy_9a9 Jul 19, 2009
    I'm on Vista 32 bit, and I already create a custom plan that says will not turn off the monitor and go to sleep ever, yet its still not working
    Problem Solver:
  • 5 Answers
You can only control the pwoer function to your pc or monitor to adjust when the screen to go to sleep mode or even shut off throw control panel power options
Posted on Jul 19, 2009
I am trying to back up my MacBook pro via the wd software and my external harddrive keeps on shutting down by itself. By that I mean the light on the harddrive goes out. I the try the same thing on the...
There is a WD utility that controls the drive setup. One thing it controls is the sleep time. This sounds like what you are seeing. I know the default sleep or hibernate time is annoyingly short. All you need to do is run the utility look for the sleep time and change it to a much longer period. I don't think it can actually be disabled but you can set it to an hour or so.
Sep 21, 2011 | Western Digital 1TB My Passport Essential...
Hi, i got acer aspire 4930 laptop,when i leave my laptop for 15minutes without working it automatically goes to sleep mode,so im facing problems when i keep something to download..plz suggest me solution...
Hi
not knowing what operating system your are running i cannot navagate you there so go to control panel power options and hopefully you will see how to tell your computer when to sleep when to turn off hard drive and monitor etc so click on the when to sleep button and extend the time to what you think you may need and you can do the same for the hard drive because i think they are normally set to cut off after half and hour by default
hope this helps
have a good Christmas
Dec 18, 2010 | Acer Aspire 4730-4947 Notebook
Spacebar puts monitor to sleep
You can reboot your HP Pavilion, and while rebooting go to BIOS by constantly tapping F1. And then there has to be an option which you need to enable "Wake up by Space bar" option. Once you enable the option, save the BIOS settings and then try whether the issue persists or not.
Regards,
soul_srch007
Dec 06, 2009 | Microsoft Windows Vista Ultimate Edition
After pc gets turned on it goes into sleep mode with no response.. need troubleshooting help.
Hello ahmid7 …
There are three potential areas for your solution (listed in descending order of probability).
1. Power Options
Are you familiar with Windows' "Power Options" control panel module? If in fact your system is going into sleep/stand-by/hibernate mode, this will be the most probable culprit, and you won't need to proceed to steps 2,3. With it you can tweak all things related to power saving (e.g., sleep, stand-by, hibernate, timed automatic MONITOR and/or hard-drive shut off, etc.). Just make your desired (re)adjustments there.
[Control Panel > Power Options]
... OR ...
Start > Run > type "powercfg.cpl" (without quotes), then hit Enter.
Once it launches, you'll probably find most everything self-explanatory. If not:
  • Search for "Power Options" in your Windows "Help and Support". Then review "…Common Tasks…" and/or "…Overview…" related items.
  • Post here again and I'll be glad to walk you thru it.
2. Monitor's OSD (On Screen Display / Setup)
If step 1 is unsuccessful, it may only be the monitor (CRT/screen/display) itself that is turning off. Somewhere on the monitor there will be an OSD (On Screen Display / Setup) button/switch of some type. There you may be able to make the needed adjustment. If necessary, refer to the monitor's documentation (i.e., User's Manual, etc.) for further details.
3. System BIOS
If steps 1+2 are unsuccessful, it may be your computer system's BIOS accommodates auto/timed shutoff of your monitor, hard-drive(s), motherboard. If necessary, refer to your computer system/BIOS documentation (i.e., User's Manual, etc.) for further details on how to adjust.
IMPORTANT NOTE:
If none of the above provides solution, please report this, because it may be that your system is NOT in fact going into what you perceive as a sleep type mode, but rather is experiencing an emergency shutdown. In this case there are a couple of most likely causes. However, there's no need to cross that bridge unless it actually exists.
Good luck, and thanks in advance for posting back ...
  • to provide clarification or feedback.
  • if you have any further questions.
  • to let me know how things worked out.
"Today's the best day of my life...and NOW you're part of it!" … Craig
Sep 19, 2009 | X2Gen MV20TP Monitor
Monitor going right to sleep mode on start up
Sounds like a bad graphics card. Try using monitor wit another computer and see if the problem still exists. This rules out the display.
Jul 25, 2009 | HP w1907 LCD Monitor
XP won't load onto hard drive.
Start the computer and press the f8 key as if to start in sage mode, but select the "Disable system reboot on error" (not sure of the exact wording on that). Then when the BSOD hits it will stay there so you can get the error number and message.
Alot of times these are memory errors so I would also suggest that you download a program called memtest 86. It is a small ISO file that will create a bootable cd to test the memory. You can get it from:
http://www.memtest86.com/download.html
Hope this helps
Apr 20, 2009 | HP Pavilion dv8235nr Notebook
Monitor shuts off
You can set your power management to ignore or control the time that your monitor, hard drive or other peripherals stay on in Control Panel or BIOS setup. It powers your monitor down to save the battery power so the computer itself does not shut down thereby losing data you may be working on. Familiarize yourself with the battery power length of time so you can determine whether this is normal or if you have a dying battery.
Oct 29, 2008 | IBM ThinkPad X60 Tablet PC
Tried to upgrade my hp from windows 98 to xp now it wont come on. It beeps then the monitor goes to sleep.Can not even run my redtore disc.
At start up of computer start tapping the f-2 key until you open the bios.In the bios change your drive order so that the computer boots first to CD-rom.
Mar 18, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
HP Pavillion dv6000 Vista notebook crashes when entering sleep mode
This is a common problem with HP Pavilion laptops, including mine. Check and make sure there are no non-OS programs running that are trying to control power settings (like a power monitor program running in the system/task tray) and then turning of hibernation in the POWER SETTINGS and then for all "WHEN I CLOSE LID" and "WHEN I PUSH THE SLEEP BUTTON" and "WHEN I PUSH THE POWER BUTTON" select DO NOTHING, then APPLY. Then SAVE SCHEME AS and choose any new name. This will disable all sleep modes forever, but at least you can get on with normal use.
If you are geeky, try going into the BIOS and DISABLING anything marked WAKE ON, and disabling anything having to do with automatic power features, and then try hibernating and so forth normally through the OS again. Sometimes this works if there are conflicting settings in the BIOS also trying to increase power efficiency.
Good luck...
Nov 08, 2007 | Computers & Internet
Computers & Internet Logo
157 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
