Question about Sony Handycam DCR-DVD403 DVD Camcorder
My sony handycam lens cover won't open. - Sony Handycam DCR-DVD403 DVD Camcorder
mistersony
  • 320 Answers
SOURCE: sony handycam "carl zeiss lens 40xoptical zoom
A common problem in the Sony camcorders is a stuck iris assy, the part of the lens assembly that regulates the light coming into the camera. It sounds like that is the problem with your camcorder. It can be verified by zooming your lens out and it and shining a light into the lens to see it you can actually see the CCD at the back of the lens. It helps if you know what you're looking for, but if all you see is black, then the iris is stuck closed and you will need a qualified tech to look at the unit. Please, if this information has answered your question, I would appreciate a good rating. Thanks!
Posted on Oct 23, 2008
Arpi
  • 326 Answers
SOURCE: Lens Cover won't fully open
Hello Tomkimball, the solution for your problem is in replacing the lens barrier. Part number is 178727811. Best regards, Arpad
Posted on Dec 23, 2006
SOURCE: sony handycam lcd sez 'cover not open'
Had same issue. Appeared to solve it by turning off USB Streaming when not connected to pc.
Posted on Aug 18, 2007
SOURCE: Sony handycam DCR-HC20 NTSC trouble
I had same problem. Got lucky and found Westpeak Electronic
Services in Calgary, AB in Sept 2009. I left it there, they replaced and aligned the ccd imager free of charge and mailed it to me a week later. I live in British Columbia.
Their number is 866-410-Sony
Hope this helps
Posted on Mar 08, 2010
SOURCE: Sony HDR-XR200 lens cover problem
You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
Posted on Aug 17, 2010
I have a Sony Handycam DCR-HC-48 and the tape door won't close along with a 32.11 error code.....HELP
Try these steps:
1. Open the tape cover fully until it clicks open.
2. Turn the camcorder on to "VCR Mode."
3. With the cover still open and the camera in "VCR mode," take out the battery.
4. Put the battery back in--out should pop your tape.
Keep us updated.
Jun 06, 2011 | Sony Handycam DCR-TRV140E Digital...
Lens Cover will not open
Make sure that your device battery was fully charge, or make sure that the unit has a power on it..
thank you
Jun 05, 2008 | Sony Handycam DCR-DVD203 DVD Camcorder
Lens cover will not open
Let me know, If you have knowledge of how to open camera and do some mechanical work, I will provide you help.
Sep 24, 2008 | Sony Handycam DCR-DVD403 DVD Camcorder
SONY HANDYCAM DCR-40
Lens cover error message comes when its not opend. There is a switch inside Front Cover (where lens and mic mounted) got bad contact. Open that Front cover and unscrew the circuit board, put 1 drop of W-40 cleaner oil and fix back all things.
Apr 27, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Lens cover won't open
I have the same problema. Have you fix it? How? I appreciate your answer. Regards, Diego dspeier at yahoo.com
Feb 23, 2008 | Sony Handycam DCR-HC96 Mini DV Digital...
DCR-HC96 Automatic Lens Cover won't open
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Feb 22, 2008 | Sony Handycam DCR-HC96 Mini DV Digital...
Lens cover not open and blank screen
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor..i know it is free for replacing that sensor cause that is one of the model that sony recall produc and the cover not open error message is a poor contact of the lens cover switch...
Sep 09, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Oct 30, 2006 | Sony Handycam DCR-HC90 Mini DV Digital...
Lens Cover will not open or close
OMG! I had the same issue and blew on the lens. To easy to be true, but it worked! I thought maybe it was a fluke, so I turned the camcorder on and off several times, and it worked every time! Sure beats the $341 Sony was going to charge to fix it!!!!
Aug 23, 2006 | Sony Handycam DCR-DVD403 DVD Camcorder
Sony Handycam DCR-DVD403 DVD Camcorder Logo
1,694 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
