Every time I initialize the printer, I'm receiving a carriage jam error. I've tried cleaning the encoder strip with alcohol, and it's still giving me the same error. What else should I try to fix this problem?
Hi, Remove the jammed
paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for
tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers
and make sure they are dry. Keep printer unplugged for about 2 minutes and
replug and try a test print. Also make sure that you have waited long enough
for the printer to heat up before giving a print job. Finally, it could be an issue with the paper
sensor. If this is the case, you will probably have to take the printer in for
servicing..
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not...
(More)
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not necessary)for my home that at least does decent photos for my personal use. Any suggestions?
Trying to scan a page from my HP 2120 printer. Pressing the scan button flashes the ''on'' light for...
(More)
Trying to scan a page from my HP 2120 printer. Pressing the scan button flashes the ''on'' light for a few seconds, then it stops and nothing happens...??
I'm trying to print large (6.1 X 8.13) Costco greeting card envelopes. I got it set up OK but the...
(More)
I'm trying to print large (6.1 X 8.13) Costco greeting card envelopes. I got it set up OK but the flap is too rigid and it jams the printer. I'm using MS Word in Office 2008 for the Mac. I tried to reverse the orientation of the printout as described in Word help but that command is not present in the Word application. It is present in the Safari application. I have spent 2 days on this. Looks like my wife will be addressing them manually. Anybody help?
Thanks, Sam
