Question about DCS 36 in. CP-366 Gas Cooktop
The two burners on the right side of the unit do not ignite when the knobs are turned to "Light" There is no clicking sound like all the others. Is it an ignitor problem? New or cleaning?
  • 491 Answers
A BLOCKAGE PROBLEM CLEAN WITH WIREBRUSH
Posted on Jul 19, 2009
Why want middle burner light automatically but will light with a lighter
That unit is suppose to have electronic quartz igniters. Apparently there's a problem but it doesn't automatically mean the igniter needs to be replaced. If you see a spark from the igniter then it's fine. If you see a spark but no flame then the ignition process is out of synchronization. In other words, the gas hasn't concentrated near the spark enough to ignite. This may be a matter of low gas pressure or the extra length the gas needs to flow to reach the center burner is impeding ignition. Simple fix is turn the knob just enough to start the gas for 2 seconds then continue the turn to click the igniter. or simply use a match. You may also see if there are any adjustments on the gas manifold that will enhance bringing more gas to the center burner quicker. Some unit have one click & that's it, others click the igniter continuously until you release turning the knob. Good luck. you'll figure it out.
Aug 13, 2015 | Verona VEFSGE365DSS 36" Double Oven Dual...
On our 6 burner gas coocktop, the right two burners don't light
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 10, 2010 | Thermador SGS36GS Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
I have a JGP636 or 960. One burner won't do
When you turn the burner knob on does the igniter click and turn off on it's own when the flame ignites? If it does then it has flame rectification. That means it can sense when the flame is on. Or does it click when the knob is in the light position and not stop until you move the burner knob? Then this is standard ignition. If it is standard ignition it sounds like it is the igniter switch built into the burner knob might be defective. Are you able to turn on any burner knob and when they are in the igniter position do all the electrodes spark or just the burner that you are turning on? If they all come on then they are wired in a series. If they are wired in a series do you get a spark at the electrode of the problem igniter? If so you can turn on one of the other burners to ignition position then while it is clicking turn on the problem burner to light it. If the cooktop uses flame rectification then there may be a problem with the switch built into the burner knob or the flame rectification sensor for that burner might be bad.
Sep 29, 2009 | GE Profile JGP636 Gas Cooktop
Burner won't light
hi gud day,i think the sensor is we have problem is hard to repair in ur own,try to call the person have expireince for repair that unit, or ur igniter ligther have damage like small broken if u hear have click is ok but much better to check the igniter coz the broken igniter is not directly spark in the burner that why is not light.to check if remove the burner base cover then see if the igniter like a small niddle color white,turn the knob to click the igniter then see it wer the spark directly if u not see it means have a broken igniter.
tns gerbee
May 26, 2009 | Amana AKS3040 Gas Cooktop
MAYTAG GAS COOKTOP IGNITER PROBLEM only 2 igniters spark
Hello
Check and make sure that the electric sending units to the side that it's not sparking ( Left side or Right side) are good, you can check that by replacing the one that works with the one that does not. they are located under the knobs on the switch rod, it's very simple, they just sit there with 2 wires, just lift and unplug the wires and replace with the good ones, and if they start clicking when you turn the knobs, then just replace the bad ones with new ones.
Hope this help
Eddie Rentas
Tupper Lake NY
Jul 29, 2008 | Cooktops
Clicks occur in "low" position instead of "lite" position
Sounds like the switch electric sending unit needs to be Ither cleaned and dry good or replced. It's not hard at all, They are located under the knob switches, you will have to remove the knobs and the top cover, they look like a small square box wit a hole in the middle with two wires on the sides, just unplug the wires and lift the box off the switch rod. cleane them and dry them good and put them back.......that should do it.....Good Luck
Eddie Rentas
Tupper LAke NY
Jul 16, 2008 | Cooktops
Two burners wont ignite
Sounds like the electric sending unit for the right burners is not working. Do you hear the cliking noise on the right side when you turn the knob to LITE? If not then you need to replace the electric sending unit, they are located under the knobs, they are a smal square box that goes on the switch valve rod, they have tow wires on the side, just unplug and lift, and look for greasse or anything that might interrup contact, you might be able to use the same ones, or just replace with new ones....Good Luck
Eddie Rentas
Tupper LAke NY
Jul 14, 2008 | Cooktops
DCS 36 in. CP-366 Gas Cooktop Logo
101 people viewed this question
Top DCS Cooktops Experts
Timllfixit
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a DCS Cooktop Expert? Answer questions, earn points and help others
