Question about Samsung SF-565P All-In-One Laser Printer
Printing When I print from my computer-the samsung will make make apopping noise and then stop - it says "print pending" but itnever prints and I have to purge the print job, turn off the samsung andstart over.
  • 2,785 Answers
Re: Printing
Scan your pc for viruses then reinstall the drivers
Posted on May 13, 2008
0 characters
3 Points
Printer won't print. I went to printer and it says there are 9 items to br pringted in queue but they won't print Printer says it is ready
Good Day Nanawhit!
That happens all the times when first print job encounter a problem and stops printing and it was followed by series of print jobs. Some reasons for stop printing could be a printer out of paper and printer not set as default printer.
The best way to fix it is to cancel all pending jobs. When print jobs window is cleared off pending print jobs, restart your PC and your printer. Then go to your printer and make sure it is the default printer.
After that try printing a test page. Once a test page is successful, you can now print as many as you want.
Jun 10, 2011 | Lexmark X2670 All-In-One Printer
Printer continues to print one line of symbols on every page. will not print anything else
Hello there Druffe,
This may be caused of any unsuccessful printing that you have initiated a while ago. You need to cancel all pending print jobs in the queue by right clicking the printer's icon in your system tray (lower right corner or your monitor) and choosing cancel printing. Also, shutdown your computer and power off the printer and unplug the power cords from the socket for like 10-15 minutes. Then after that, power on the computer and printer again. The pending print jobs should be deleted and you can start printing again. Good luck!
Dec 12, 2009 | HP Printers & Copiers
The printer turns itself on autamaticcally and wont stop printing
You need to cancel all pending print jobs on the queue. If you see the printer's icon on your System Tray, lower right corner of your computer, right click it and choose Cancel Print Jobs. Or you can double click it so that it will show you the current printing job or those in queue. Select and delete them. If this does not cancel the pending print jobs, disconnect your printers power cord and shutdown the computer. After like 10 minutes, turn the printer and computer back again.
Dec 01, 2009 | Dell Printers & Copiers
My 8050 is printing symbols and jargon instead of text. Help
ok disconnect ur printer frm ur computer and turn it OFF for 5 min,after 5 min turn ON it again n dont connect it to the will not print those symbols
now on ur computer check that is there any pending printing or last time u used da computer to print and its left on pending.ckeck it on where the clocks is shown on taskbar.if yes so cancel all the pending printing and then connect ur printer back to computer.then u shall not face the problem.
Nov 29, 2009 | HP Photosmart 8050 InkJet Printer
Always pending to print but not printing. help. pls. i have been printing consistently from this printer using my laptop and suddenly one day without doing anything it simply keeps ending up in the pending...
click on start-->control panel-->administrative tools-->services. in the services list look for print spooler. right click on print spooler click on stop and again right click on print spooler click on start.
turn off the printer and turn it on, try to print
Sep 30, 2009 | Printers & Copiers
Canon mx310 it won't stop the printing the buffer won't clear
First things to do is check the Printing Preferences of your Printer if it has a pending printing jobe to do, there you can able to cancel and stop the printer to print.
  1. Go to Control Panel
  2. Select Printer & Faxes icon
  3. Right click on the printer you are using
  4. and the Select Printer Preferences.
  5. Select and right click if you see any pending document,
  6. click cancel.
Hope this helps.
Jul 19, 2009 | Canon PIXMA MX310 All-In-One Printer
How can I cancel pending printing with my HP Deskjet D 1455?
You need to go to 'Printers' in Windows, and click on the document in the window to highlight it. Then one of the menu items gives you the option of deleting it.
Turning the machine off does not stop it because the print is held in Windows until the printer says 'thanks, done that', and if Windows senses that the print sequence has failed it simply tries again - and this happens, of course, when you turn the printer off and on again. Werry irritating.
Jun 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
PC Print Pending Message Won't Go Away
Have you tried to delete the print job from the computer? After that is done reset the printer by turning it off (30 sec) then on again. If that doesn't work take the paper out and start cleaning your printer with canned air, Q-tips and a cap full of water.
Dec 10, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Samsung ml-1250 Printing stopped
Try purging the 3 pending print jobs then try to print again. Go to Printer and Faxes on XP, then right click on your printer icon then select purge print jobs. Or double-click on the printer icon on your system tray (lower right hand of the screen) then click on the pending print jobs then purge it. Then try to print again.
Oct 21, 2008 | Samsung ML 1250 Laser Printer
Will not print
Try unplugging the USB cable from the back of the computer, not from the back off the printer. Also, try deleting the printer from/at the printer/fax page and restarting your computer so it will reinstall. In either case, when checking the printer/fax folder, make sure there is nothing pending printing. If there is, click on delete all pending printing jobs. If there is a print job pending and you can not cancell/delete this job, then you must delete the printer icon and restart your computer. Aloha!
Sep 20, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Samsung SF-565P All-In-One Laser Printer Logo
121 people viewed this question
Top Samsung Printers & Copiers Experts
Level 1 Expert
 Mike M
Mike M
Are you a Samsung Printer and Copier Expert? Answer questions, earn points and help others
