Question about Garden
Have a Ryobi 30530. Reloaded trimmer string for first time, according to instructions, orange knob on bottom of trimmer flys off after starting and acceleration.
SOURCE: ryobi weed trimmer
I have one of this trimmers. It is simple to replace the line.
-First line up the arrows on the bottom of the spindle.
-Then feed the line back in one of the holes in the side of the spindle (this is the same hole that the cutting string comes out of).
-You will see the line come out of the bottom of the spindle.
-Take that line a place it in the hole on the bottom of the spindle.
-Leave about 9 feet of string hanging out of the weed eater (do the same with the other side).
-Then turn the inside wheel (I can't remember if it is clock wise or counter clock-wise but it will only turn one way) most of the string is rolled into the spindle.
-Cut the string of about 5 inches out of the weed eater. You're ready to cut!
Posted on May 31, 2008
AlmostBob
  • 550 Answers
SOURCE: Gas/oil mix ratio for Ryobi Trimmer
50:1
Posted on Oct 10, 2008
mitchjl_1692
  • 3 Answers
SOURCE: Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
Posted on May 27, 2009
AUTODOC01
  • 216 Answers
SOURCE: I need to know how to load a two string trimmer
most of these use 2 wires coming out of 2 holes on opposite sides roll the firstwire clockwise, then the 2nd counterclockwise so that when the spool turns the string comes out its not hard
Posted on Aug 25, 2009
  • 124 Answers
SOURCE: Bought a Ryobi weed trimmer CS26 from Home Depot.
just cheap equipment. Mark it up to experience and do not purchase equipment fro home center or box stores ever again.
This is just one of the many problems of dealing with
the box stores rather than a full service qualified dealer. If you can
find one in your area, patronize them. Not just when the box store
lets you down but for everything. These type dealers are
disappearing and are not being replaced and soon they will all be
gone.
Posted on Sep 14, 2009
I need an operator's manual for a ryobi string trimmer model RY 30530
try ereplacement.com or contact me at richnford@yahoo.com im sure i can find ya one .
Jul 06, 2011 | Garden
How do you put new line on
If you have a push release line version, this is relatively simple. The push release is normally a orange knob at the bottom of rotor and lets lines through as required.
First thing first, line the arrow on the orange knob to the two hold where the line comes out. This will line up the mechanism inside, cut a length of line (about two arms lengths) and feed the line into one of the holes (it doesn't really matter which one).
it should just go from one end to the other, if your line is like mine, it normally curls, but a little fiddling should do the trick.
Once you have it fed through, put it even on either side, then push the orange knob and turn at the same time to wind the line back into the line holder. leave enough line out so that you can start using it.
Jan 19, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
When in operation the Ryobi S430 string trimmer leaks oil continuously. How can I fix this problem?
Ryobi told me the unit can't have the s430 trimmer bottom end raised higher than the engine at any time, or it will leak. Apparently they released a product to compete with other companies for cheap 4 cycle trimmers without much care for the end user.
Nov 29, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
HOW DO I INSTALL A NEW STRING IN A PRO CUT 11 for Ryobi RLT30CD trimmer
LINE REPLACEMENT (Fig. 8) (For Reel EasyTM Head) Use 2.4mm monofilament string. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Cut one piece of string approximately 7.6m in length. n Rotate knob on string head until line on knob aligns with arrows on top of string head. n Insert one end of string into eyelet located on the side of the string head and push until string comes out through eyelet on the other side. Continue to push string through the string head until the middle section of the string is inside the string head and string outside the string head is evenly divided on each side. n Rotate the knob counterclockwise on the string head to wind the string. Wind the string until approximately 20cm remains protruding from the string head. INSTALLING STRING IN PRO CUT II STRING HEAD Use monofilament string between 2.4 mm and 2.7 mm diameter. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Gather two of the pre-cut lengths of trimmer line provided or cut two pieces of trimmer line, in 28 cm lengths. n Insert the strings into the slots located on the sides of the string head. String should be pushed in until approximately 2 cm protrudes from the holes on the top of the string head. n Remove old string by pulling it from the holes located on the top of the string head. http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Oct 29, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do you change the string feeder on a ryobi gas
If your machine is a "bump feed" there should be a knob on the bottom of the string feed.....this is a LEFT HAND thread, so turn it clock wise and it should pop free and unscrew....re-string your cartridge and replace it tightening the knob counterclockwise until it stops....that should do it !!!... ;-D
Jul 10, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Bought a Ryobi weed trimmer CS26 from Home Depot. The second time I used it string broke both ends. Could not take it apart went to Home depot after 30 days they could not take it apart. They would not...
gone.
Sep 05, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
Require Manual for Ryobi PTL 2543 25cc line trimmer
Or sometimes you unscrew a retaining bolt set into a plastic "lug", the spool drops out, refill t with line, replace it putting line through holes in the spool casing, refit the "lug" and tighten it again. I think I have the manual for this though and if so maybe I can send you a link to images on MSN Homepage to help you..
Feb 22, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi Trimmer
To install string in the Ryobi you do not have to disassemble anything: Line up the two arrows on the inner and outer reel, remove any excess string, cut two pieces of string about 10 feet, feed line in the side holes, secure line in hole where it comes out the bottom (it only takes about 1/4in. to do so), pull strings tight, then turn the inner reel counter clockwise to wind it. If it sticks a little just pull line a little.
To remove the inner spool in order to remove line that has broken inside, to clean the mechanism, or to perform other maintenance, grasp the outer reel and unscrew the bump knob counter-clockwise. Mine is often very tight and requires pliers to get enough leverage. While you are in there, clean the inner reel and the inside of the outer reel to improve feed performance. The shaft rarely needs cleaning. Do not lubricate. After re-installing the reel, add string (0.080") as described above.
Sep 09, 2007 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
139 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
