Question about Maytag Neptune MDE5500AY Electric Dryer
Loose fins One of the fins in my Maytag Neptune is loose and I need to know how to tighten it?
    President:
  • 1,136 Answers
Hi, Unplug the dryer. Remove the screws on each side of the door opening. The front will pull toward you and lift off the clips at the bottom. You have the option to take the door off or leave it hang there. With the front off, you should be able to reach in and tighten the screws that hold the [addles in place. Just turn the drun by hand to get to the next paddle. You will need a 5/16" or 1/4" nut driver/socket.
Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Posted on Jul 19, 2009
Fin that tumbles clothing inside dryer coming loose, how can I tighten it?
These fins are usually screwed on from the outside of the drum. If you're up to it this is a simple but time consuming fix. Take the cabinet off the front of the dryer, the top will come off as well. be careful of the wires from the control console, they will stay attached to the dryer. Tighten the tumbler fins on the drum and then re-assemble the cabinet. Typically the screws you need to access are the same used for the door latch and hinges. They go back together easy ........
Feb 14, 2011 | Maytag Neptune MDE7500AY Electric Dryer
One of the dryer fins is very loose. How do I tighten it?
REMOVE SCREWS FROM DOOR HINGES AND OTHER SIDE REMOVE DOOR THE FRONT DOOR CLIP REMOVE CORNER BRACKETS LIFT UP FRONT LID AND TIGHTEN SCREWS ON FINS
Jan 25, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Neptune Dryer Blades
Yes - right where the front panel meets the top panel of the dryer on both sides there are two clips. Insert a screwdriver into the clips and push up on top panel. You'll see the screws that hold the fins on the dryer. Tighten these screws or replace. Good luck...
Nov 16, 2009 | Maytag Neptune MDE5500AY Electric Dryer
One of the "fins" inside the drum has become loose. It hasn't come off, it's just loose...how can I fix it? Thank you!!
hoping it is a neptune.........
remove the screws on the door hing to cabinet
and the two opposite
lift and remove the door
once the door is off
you can pull the front panel off
grab the thin sides and twist in and pull
onvce tat panal is off you will see two 5/16 screws on each side
remove those
you should be able to lift the top
once you do you should be able to see the top of the tumbler
turn till the loose fin is on top and just tighten the screws back out and your good to go
Oct 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Loose paddle
Pop the top ... remove the front ... carefully remove the belt ... take the drumout - you are correct, the paddles are held onwith screws - tighten them.
reassemble
Oct 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
The fin on the Neptune Dryer has come loose and I need to remove the side panel on the dryer to replace the two screws that hold one of the three fins in place. It would be simple if I knew exactly how to...
Remove the 2 screws holding the door and the 2 screws on the other side of the door opening . Pull the front panel foreward and lift off . If still not enough room to reach under to tighten , remove the 2 screws (1 on each side , holding the top down , then lift top . DISCONNECT POWER BEFORE DOING ANY WORK .
Aug 18, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Loose shelf in Maytag Neptune dryer
Hi, UNPLUG the dryer. There are two screws on each side of the door opening. Remove them screws and the front should pull toward you and release.The door can either lift off or remain on. You can reach under the drum and tighten the screws.
I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
May 31, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune model MDE5500AYW loose tumbler in drum
I had the same problem but it's the FRONT Panel you need to remove. Before you start, unplug the thing first. BTW I did the whole proceedure in 10 minutes using an electric screwdiver / philips bit and a socket set with an 8mm socket with my leg in a cast. You can do better, I'm confident!
Two 8mm hex head bolts hold each fin on the drum. They can be tightened. You need to open the dryer front since they bolt from the outside of the drum. To open the dryer front you first take the door off by removing the two philips head screws, then slightly lift the door and pull toward you (the door hinges have little hooks on the end that inserts into the slots (this little design keeps the door from falling off during removal and install-nice). Then remove the two philips screws on the other side of the door opening (opposite the door hinges). These screws hold two plastic brackets (be sure to see how they are aligned before you remove them so you know how they go back on.
Now the front frame panel looks like an "H" . Grab the top two arms of the 'H" and give a quick pull. The top arms of the 'H" will come loose. The bottom part is held by a couple of clips, just pull up and the front panel comes off.
You will be able to spin the drum until the hex bolts for the fin(s) in question are visable / reachable from the right side (just above the heater unit-hope you unplugged the dryer earlier). I tightened it using an 8 mm socket.
Now reverse your steps: put the front panel back on the bottom clips and snap the top "H" arms back in place. Reinstall the plastic clips / screws and then put the door back on.
Apr 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
FIn inside neptune md55 dryer came loose need to remove side pane
Now the front frame panel looks like an "H" . Grab the top two arms of the 'H" and give a quick ****. The top arms of the 'H" will come loose. The bottom part is held by a couple of clips, just pull up and the front panel comes off.
Feb 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Neptune gas dryer
Did you check the baffles( fins inside the drum) loose of broken.
Can you turn it by hand and hear the same sound? does it turn easy or very hard...let me know I can help
krazytech
Mar 23, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
226 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
