Question about Craftsman 24 Hp 48" Deck Yard Tractor
How do I remove electric clutch pulley on Craftsman 917.257720 lawn tractor?
  • 21 Answers
If i'm not mistaken there should be a bolt in the center of the clutch that screws to the crankshaft remove top cover and have someone hold a wrench or socket on the top nut while another unscrews the bolt running through the clutch (righty tighty lefty loosey) may need to unbolt the steel rod that keeps the clutch housing from spinning. also dont forget to unplug the wires hope this helps
Posted on Jul 27, 2009
HEAVY VIBRATION OF MOWER DECK (CRAFTSMAN17.5 HORSE TRACTOR?)
Even new blades can be out of balance, but my guess would be either the other blade spindle, or the tensioner pulley bearing.
Apr 05, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I get the lever to shift to lift the mower so that I can replace the belt? 19hp, 42", year unknown craftsman turbo
If it is the drive belt do the following place your mower on a level surface set parking brake, remove mower deck, remove belt from stationary idler and clutch idler, pull belt slack towards the rear of tractor , then remove belt upwards from transaxle pulley by deflecting the belt keepers, then pull the belt towards the front of mower and remove downwards from engine pulley Install new belt in reverse procedure
Jan 22, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How to install clutch in craftsman lt 1000
there is no clutch,, you have an arm with a pulley that is spring loaded .. when u release the " clutch" this arm pulls a pulley against the belt taking up the slack ,, make sure the belt is not worn ,, or the spring is broken or loose
Apr 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman 17hp lawn tractor shutters bad when releasing the clutch pedal. is it the clutch and where is it located?
Its not really a clutch, clutch/brake pedal when pressed will release belt pressure which stops pulley from turn axle. When predded all the way down it mechanically applies brakes. The vibration is from a bad pully that the drive belt rides on or a bad belt. Look for chucks of belt missing.With engine off put on parking brake and manually wiggle each pulley that drive belt rides on to see if there is any play. No play should be present. Good luck.
Mar 20, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Where can i fine manual for engine replacement
TO REMOVE THE PULLEY FROM THE CRANKSHAFT END:
Remove the blade belt and, if needed, the deck to give yourself more room to work. Apply your brake pedal and lock it down, this will relieve the tension on the ground drive belt.
If you have an electric blade clutch, find the plug where the wire goes over from the clutch to the frame and unplug it.(Electric clutch will be heavy when unbolted so be ready for it.)
In the center of the pulley or blade clutch you will find a long bolt (most likely a 5/8 head on it) You may need a deep socket to reach it depending upon the type of stack pulley on it, remove this bolt and the pulley should slide freely on the crankshaft. slide it downward and slip off the belt on the top of the pulley then remove the pulley the rest of the way
Oct 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Primary mower belt on my Craftsman 48" lawn tractor has worn out prematurely. I installed a new belt this spring, & after less than 25 hours of service, it is 75% shredded from the inside. When I...
Hi. The belt must be trying to move a pulley that is either frozen, partially frozen or excessively loose. remove the belt and check the action of each pulley. If you have a frozen one, use some WD-40 to unfreeze it and if you have an excessively loose one replace the entire pulley assembly as it is worn out.
Jul 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 24 Hp 48" Deck Yard Tractor Logo
1,090 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
